Question about Actiontec Computers & Internet
Epson artisan 800 printer won't print wirelessly with new router
  • 58 Answers
SOURCE: My new linksys router doesn't allow me to print
Try deleting the printer from the PC then browse for network printers and set it up again....
Posted on Mar 13, 2009
  • 10 Answers
SOURCE: can't connect printer
Click Here .. Right from Epson's own forum ...
Posted on Aug 20, 2009
  • 3 Answers
SOURCE: epson artisan 800 will not print
please make show that ur connection to the printer is correct.mostly if u using usb cable.uninstall and reinstall ur printer drivers can solve the problem.
Posted on Apr 19, 2010
SOURCE: Hooking up Epson Artisan 800 to wireless. Get all
You must set both devices to the same encrypryption protocol, WEP or WPA. That being said, I had to setup my router using WEP - the printer refused to connect via WPA. Good luck.
Posted on Jan 26, 2011
  • 37 Answers
SOURCE: I hooked up a N150
Here is a manual to set-up the network: http://www.ehow.com/how_2036282_remove-dvd-player.html. Pages 4-8 should get you were you are going. Good Luck!
Posted on May 17, 2011
Epson Artisan 800 won't print with ink in the cartridges.
Have you run the head cleaner function under the maintenance section? You may have to run it several times. Then make sure that you print something that uses the colors every week.
Aug 06, 2013 | Epson Artisan 800 All-In-One InkJet...
I don't know how to disable "keep printed documents". I have an Artisan 800 series printer.
Hi Michelle,
Follow the steps below and you will be able to fix the issue.
Click on START button
Click on Control Panel ( or Settings for windows XP )
Click and open Printers and Faxes ( or Printer folder icon )
Highlight the Printer icon and Right click on it
Left Click on Printer properties
Click on Advanced TAB on top and look for "Keep Printed Documents"
If there is a Check mark, you can Uncheck it.
If there is no check mark on it, Check mark it.
Click Apply/OK and Close the window and try to print.
If this does not resolve the issue, Try the step below
1. Open Printers and Faxes.
2. Right mouse click on the Epson printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Regards,
Sean
Sep 14, 2012 | Epson Artisan 800 Series
I can't get my printer to print. It seems to be stuck on Paused.
If your printer is connected via wireless network, please try the following.
1. Check if WiFi light indicator if enable and has signal strength.
2. Check if your computer is connected to your wireles router.
3. Reinstall the printer driver.
If your printer is connected via USB cable, please try the following.
1. Check if the printer and computer is properly connected.
2. (for Windows), Check Device Manager if USB Printing Support is present, (for MAC) Check Apple System Profiler if EPSON MFP 2.0 High Speed is present under USB device tree.
Nov 03, 2011 | Epson Artisan 800 All-In-One InkJet...
My Epson Artisan 800 prints only 1 inch of anything and then spits the paper out
Try the following to resolve this issue.
1. Check if same issue appears when using your Artisan 800 as a standalone copy machine.
2. Try printing from a different application to isolate the issue further. You can also print a windows test page to check if this issue is caused by the application that you are printing from or by the printer driver.
3. Reinstall Printer Driver.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
I have bought an Epson Artisan 835 printer & can't get it to connect wirelessly to a Billion Router (BiPAC 7300G).This router is connected wirelessly to my i-Mac. I currently have the printer...
1) Please check your router setup whether it does not allow Wireless devices to ping against each other;
2) If it does not allow to ping (communicate) with each other, please disable it first.
3) Then please check your Epson wireless setup whether the DHCP function is enabled; if not, please enable it;
4) Please also input your network gateway, sub-net mask correctly into the Epson printer, otherwise the wireless communication with your network will not work.
5) Then switch off your printer and turn on again to recognize the new settings; and it should work
Aug 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I am trying to print to my epson artistian 810 and it will not print. I have tried reinstalling the software and drivers and checking the wireless connection but it has done no good. How do I fix this...
When you purchase an Artisan printer, you are entitled to free premier phone support from Epson. This troubleshooting will best be handled on the phone with Epson. Check the website for the latest driver and compatability with your system. Check their troubleshooting steps.
Oct 20, 2010 | Epson Artisan 800 All-In-One InkJet...
Cannot print on wireless printer
..goto setting and disable the wireless setting on your printer.. then you should be able to print..
May 22, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 800 will not print
Apr 19, 2010 | Epson Artisan 800 All-In-One InkJet...
Jan 10, 2010 | Epson Artisan 800 All-In-One InkJet...
Computers & Internet Logo
52 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
