Question about Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by
Bathroom Faucet Handle Fell Off
I need to learn how to re-attach and fasten the handle to Moen Monticello model Bathroom Faucet.
  • 374 Answers
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do I replace handle adapter kit for Monticello?
    Unthread the handle hub (ccw), once detached, turn the handle upside down. There is a Phillips screw inside that once loosened (ccw) will allow you to replace the adapt.
    Feb 18, 2015 | Moen Bathroom Sink Faucet - 4-inch...
    How do you replace handle adpater for moen 8400 monticello faucet
    The handle adapters that Moen makes are right and left. Because you bought a universal one, it works on both the right and left, but only turns one way. If you but an original Moen part, you won't have this problem.
    Sep 15, 2017 | Moen Bathroom Sink Faucet - 4-inch...
    Replacing the handle adapter on a 4-inch moen monticillo bathroom faucet. Can't get the handle hub to unscrew with a strap wrench. tried using lime away to cut the 15 years of crud around the handle...
    Sometimes there is a small set screw located on the handle.It takes a small allen wrench to loosen it.That should enable you to remove the handle assembly.
    Jun 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
    My moen bathroom sink handle came off. The srew into the handle comes up from the stem? how do I access the srew to reinstall handle? Thank-You
    pop the cap off top of handle with steak knife, screw is underneath,unless yours is like the one pictured,then its an allan screw from the back.you had one when it was installed and,these can be really stuck
    Jan 28, 2011 | Moen Bathroom Sink Faucet - 4-inch...
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Leaky moen 2 handle faucet
    if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    Have a 4 inch center moen that has solid handles with a decorative piece on the bottom. How do I remove the handles?
    if it is like your picture then you have a monticello faucet. The handles unscrew. The ball looking part of the handle unscrews just like you are loosening a nut. Then you will be able to get to the cartridges,
    Apr 10, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    My Monticello has a loose handle.
    If you click on the "Illustrated Parts Diagram" link in the link attached, you will see in the link below how you just need to twist the elbow in order to tighten it onto the hub.
    Sep 20, 2009 | Moen Bathroom Sink Faucet - 4-inch...
    Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by Logo
    3,162 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
