I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by. Also if you try to mute sound or change channels when first turning on the TV locks uo and you have to unplug and start over.
  • 2,326 Answers
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to if you require further assistance.
Posted on Mar 11, 2009
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
We have a Polaroid TV, Model FLM3732. When we turn the TV on, there is a loud pitching noise that lasts for 3-5 minutes, and then goes off and runs normally. Is there anything we can do to trouble shoot?
The high pitch you are hearing is probably due to failing electrolytic capacitors in the power supply module. Eventually this will no longer function. A tell tale sign would be swollen caps "tops are convex" on this pc board usually 1000mf 25 v caps or simular. I would refer to competent tech for repair of module to component level.
Mar 04, 2010 | Polaroid FLM-3732 Television
I have a Polaroid 37" LCD TV (FLM3732)
it could be 2 caps on the power board, i had the same problem and for $3.39 at Radio Shack solved it.
There is a link on hre with pictures and instructions from stiv0, that works. Of course your on your own if you try it.
Sep 30, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Polariod LCD FLM3732 does not show picture but has power
Its possible that you have some bad Electrolitic Capacitors. They are a very easy fix and very easy to see if they are bad. I have some vids posted on youtube on the fix for this. It only costs a few dollars to do. Just search on youtube for flm3732 repair or go right to my channel and watch the 5 short vids I had posted.
May 26, 2009 | Polaroid FLM-3732 Television
There is an easy fix for this. You can go to youtube and look up flm3732 repair or just visit my channel my sn is Raider2845. It only cost me a few dollars to fix the tv. Its very easy and just about anyone can do this.
Mar 14, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
