Question about Panasonic KVS1045C
KVS1045C - I NEED THE EXIT EXTENSION TRAY PART WITH EXIT STOPPER
PLEASE - wassearman@gmail.com
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
My strainer/stopper is stuck in kitchen sink drain. How to remove it?
If it's not visible from above then you must remove the trap j-bend. Go under the sink and put a big bowl or tray under the trap because when you remove the j-bend water will come out. You'll need a 12" grooved pliers, like channel locks, to get the nuts off. There are two of them. If the trap is old brass or chrome you may end up cracking the j-bend. If it's white or black plastic you can probably remove the nuts by hand. Look in the j and pull out your stopper. If it's visible from above a long pair of needle nose pliers would work best to remove the stopper.
Jan 31, 2011 | Blanco Sink Waste Strainer / Stopper...
Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
I need to replace document tray. Can you help?
hi ,
please follow the onscreen instruction and i am preety sure this should fix the problem for you
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00840272&cc=us&lc=en&dlc=en&product=2512010
Please follow the instructaion for installing the tray from above mention URL hope this should fix the problem
please let us know if you still face any problem we would be more than happy to help you once again
thanks
regards
HAMID
Feb 20, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
My canon pixma iP4300 keeps telling me to open the out put tray, and i do but it still doesn't work. What should i do to fix this?
Just below the "Canon" logo on the front panel there should be a door that releases and drops to reveal the print exit tray. There should also be an extension handle that pulls out of the drop down door to support the longer sized pages such as letter or legal.
Don
Oct 22, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Thermos Vacuum Bottle Stopper No. 781
You can get replacement stoppers for the 781 by using the 750
This is currently available on Ebay and he ships worldwide
Here http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180592070973&ssPageName=STRK:MEWNX:IT
Jul 29, 2009 | Sport & Outdoor - Others
Brother MFC8840D says Out of Paper but tray is full. I have tried moving the DX lever and I have reloaded the paper tray and adjusted the paper. Help
make sure the rear paper stopper in your paper cassette is not pressed too tightly against the rear of paper. best to leave an 1/8" gap between the paper and stopper.
good luck,
ray
Jan 26, 2009 | Brother MFC-8840D All-In-One Laser Printer
Need to change extension names on a MLX-20l phone
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Jan 13, 2009 | Lucent Merlin Legend MLX-10D Phone
My Ex-Z60's battery stopper
Battery stopper can be fixed in repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Mar 18, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Panasonic KVS1045C Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
