You have a PCIe x16 slot (not 2.0), therefore head online and find yourself a PCIe x16 video card on
this website. Once the page loads navigate to Computer Hardware>Video Cards & Video Devices. Once the page loads select Desktop Graphics / Video Cards on the top-left. Afterward look on the left again and selecet the Interface of, "PCI Express x16." Remember, you
do not have PCI Express
2.0 x16!
Now you will have a list of PCIe x16 video cards, all of which should fit into your computer. Once you receive your video card in the mail, open up the left (To the left of the power button) side-panel of the computer. You might have to unscrew it from the back, then it should slide back, and pop off.
Now, since I don't know if you have an actual video card or integrated video, we will need to do some investigating. Look at the region where the monitor's cable connects to the computer. If it connects to a device secured in a slot marked in this
picture, we know you do not have onboard graphics. If it doesn't connect to a device seated in one of the slots marked in the above picture, we do know that you have onboard graphics.
If you don't have onboard graphics, follow these steps below, otherwise skip this section.
Disconnect the cord that connects the monitor to the video card. Now unscrew the video card from the case (There's only one screw holding the video-card to the case, it is marked with the red-box on the left in this
picture). Afterward, hold the metal part and very end-tip of the video card (demonstrated in this
picture) and slowly pull out the video card. Once you have removed the video-card, place it on some form of cloth to prevent dirt from entering any parts of the video card.
Installing your new video card: Take the video card out of the package. Find an empty PCIe x16 slot (They are colored pink and sky-blue in this
picture, it doesn't mean your slots will be colored the same). Now hold your video card on the points shown in this
picture. Now slowly insert the video card into the PCIe x16 slot ensuring that the golden-colored pins enter the slot. Afterward secure your video-card by screwing it to the case (marked with the red box on the left in this
picture).
Afterward put the case-siding back onto the case, slide it towards the front of the case, and secure the siding by screwing it in place.
Now connect the monitor's cord to the new video card. Afterward power up your computer and download then install this:
http://downloads.guru3d.com/Guru3D---Driver-Sweeper-(Setup)_d1655.htmlUse the tool to locate and remove
all NVIDIA drivers. After the tool finishes, restart your computer. Now use the CD that came with your new video card to install the drivers of the new video card. After the installation finishes restart your computer, you should now have your better graphics back and your video card should be in operating order.
Now as for the viruses...
Download these utilities:
ESET NOD32 Antivirus (Download the free trial):
http://www.eset.comLavasoft Ad-Aware Free:
http://www.lavasoft.com/products/ad_aware_free.phpSpybot Search & Destroy:
http://www.download.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html?tag=mncolAVG Anti-Rootkit Free:
http://www.softpedia.com/get/Antivirus/AVG-Anti-Rootkit.shtmlNOTE: When installing Spybot Search & Destroy,
do not install TeaTimer.exe! Doing so will interfere with NOD32's active monitoring abilities. You will be asked if you wish to install it during the installation of Spybot.
Now, after you installed all of the utilities, run updates on them until you're told there are no new definitions available. Then we start scanning.
First run a, "Custom" scan with NOD32. Check off everything and run an, "In-Depth" scan. Check in on the scan every once-in-a-while as it might ask you what to do with a malicious file (Just don't accept any offers to restart the computer). After the scan finishes run a full-scan with Ad-Aware. After the scan finishes check anything found and remove it/them. Now run a scan with spybot search & destroy. Fix anything found. And then run a scan with AVG Anti-Rootkit Free. If it finds anything it will be up to you to keep the file or remove it.
Hopefully that solves your virus problems, if not, a reformat may be in your near future.
Let me know if this answers your questions. I'll be more than happy to assist you with anything further.
Comments:
Mar 11, 2009
- Oh, yes. I forgot about the power. Make sure that when you're removing your old video card and inserting the new one that there are no power cords connected to the computer. You may also want to touch the metal chassis on the inside of the computer to discharge any static electricity. That way none of the components are messed up if you touch them and have static built up.
Mar 11, 2009
- Alright, so you will have a somewhat simple transition to a newer video card, as you cannot replace the onboard video. However, once you get the new video card installed, you still want to use the driver cleaner to remove all NVIDIA drivers. After the installation of the new video card you might have to enter the system BIOS and disable onboard graphics.
Let me know if I can help you further.
Mar 12, 2009
- Not a problem. I myself agree that the prices at places such as Geek Squad are simply ridiculous for such a simple task.
Take care.
