Question about Dymo LabelWriter 400 Thermal Printer
Lablewriter 330 turbo error code 0x800f0214
I am trying to Install software for my new label printer and it wont install due to this code coming up please help
3 Suggested Answers
  • 14 Answers
SOURCE: My dymo label writer twin turbo stopped printing on left side!
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Posted on May 06, 2010
SOURCE: Dymo Labelwriter 450 Turbo errors
450 label is stuck in machine. How can I fix this problem?
Posted on Sep 04, 2010
Brady TLS2200 won't feed labels. no errors.
Turn off the printer and open the printer back door. Use a spot light and look inside properly. Make sure there no paper. Some times a small piece of paper creates the problem. Then after open the back door, top side turn the printer upside down . So if anything is inside it will come out.
After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software (Check if there are any new drivers on the website) .
Feb 25, 2014 | Brady TLS2200 Thermal Label Printer
Won't print from another mac as can't find printer
You can try going to System Preferences and pressing Resume to make sure the printers are not off line. Otherwise, please contact us (see dymo.com for numbers).
^CM
Dec 26, 2013 | Dymo LabelWriter 1752266 450 Twin Turbo...
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Dec 11, 2009 | Dymo LabelWriter Thermal Printer
What is the life expectency for these? Mine doesn't come on even with the AC plugged in
We've had our Dymo 330 Turbo for years and still use it daily to print all our address labels - never had a problem with it. They come with a 3 year warranty, so I guess Dymo thinks they're going to last at least that long.
If the power supply has had it you can get a replacement power adapter but if the machine has had it then time to get a new one I think.
The 300 series was discontinued years ago, and even the 400 series has now been discontinued and replaced by the Labelwriter 450 series.
Oct 24, 2009 | Dymo LabelWriter 330 Thermal Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
I have an error code on my printer Error Code: E100 0000 .
uninstall the printer and install the new software of the printer and it will run rate me please
May 23, 2009 | Canon imageRUNNER 330 Printer
We have a microline 320 turbo. we installed a new dell computer and now cant get the printer to print corectly on contineas feed labels. The print head starts on the right side and prints off the sheet...
Try downloading and installing an updated driver for your printer.
Here is the driver download page for your printer: MICROLINE 320 TURBO < Drivers & software
Select your operative system, download the file, then run the installer.
Mar 03, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Lables i was loading has gone in but has not come out the front
When loading the label roll..place it along the left edge then press to button on front of the label printer once and dymo will **** it in. Now it's ready to print labels. Be sure to unplug the printer and plug it back in to avoid the common "printing error" message from windows.
Jan 22, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo Twin Turbo install on network
You need to download the Dymo software 7.8 from Dymo. Start with the system that has the printer plugged into it. Install the software and make sure it works (prints labels) Now go to Printers and Faxes and find your printer. Right click and choose properties. Then the Sharing tab. Choose a share name that is simple. The printer will now be know to other installs as \\computername\sharename
Go to the next computer and install the software - CHOOSE NETWORK when you get the part about connection. Either enter your host computer info from above or BROWSE to it via Windows Networking. All should be fine now.
Dec 08, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
139 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
