Question about Samsung LN26A330J LCD TV
How to change default volume setting
When I turn on my tv the volume is at the highest setting - very disturbing. Also I use it as a monitor and when I wake up the computer it goes to tv instead of pc (I think because the default setting to go to pc is just a few seconds off). I called the help desk and their only answer was to return it to the factory setting (which was the highest setting). Any help would be appreciated for this VERY annoying problem. Model ln26a330j1d.
Thanks,
Vicki
SOURCE: samsung phone does not ring
thanks for the help it worked
Posted on Jul 11, 2008
SOURCE: key tone volume
press the down button on the left hand side of the handset, this controlls the key volume
Posted on Nov 05, 2008
GregL
  • 49 Answers
SOURCE: screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Posted on Jan 20, 2009
  • 23 Answers
SOURCE: Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Posted on Aug 14, 2009
  • 1684 Answers
SOURCE: Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 24, 2009
Volume too low
are you using the monitor's volume or are you using speakers? If its monitor volume, I would say go into the main menu of the monitor by pressing the menu button. Then go to the volume setting and raise the level. If the volume level is already on the highest, you may want to consider using another solution to monitor sound, such as speakers or headphones connected to your computer.
Oct 18, 2012 | ASUS Vw223t 22" Widescreen LCDFlat Panel...
Hello, I'm trying to increase the volume on some phones mitel 5220 and 5224, but it only goes to 6. I need the volume level to go to 10. Do you have any ideas? Firmware is 07.02.00.04 Thank you
The ADA compliance requires that the phone when set to the highest volume level will revert back to factory default setting for the next call. This is a safety feature to prevent one's hearing aid from being blown up by a loud caller.
If you turn the volume up to 9, and leave it there, it will stay at 9. If you turn it up to 10, it will always revert back to default.
I hope this helps,
Mark
Feb 08, 2011 | Mitel 5220 IP Phone
I cant hear people properly when they ring very low how do i turn volume up have tried but only goes to 5
The manufacture generally set a default setting on the highest volume to match the speaker. So it does not pop. If you have it at the highest settings then that is the loudest the manufacture allows it.
Oct 21, 2010 | Cell Phones
I do not know how to turn off silent mode on a samsung SGH-U600 mobile phone
You can turn the phone on and off
Silent mode to avoid disturbing
other people. In Idle mode,
press and hold [#].
Sep 25, 2010 | Samsung SGH-U600 Cellular Phone
I disturbed settings of compaq 7500 crt monitor, with the front 3 control buttons. How to set back to default settings? Any help is highly appreciated.
there should be a default setting in under the menu (on the monitor itself) browse though the menus using the up and down again, look for that defaults option and select it, most monitors have this. hope that helps. use the thumbs if it does.
Aug 26, 2010 | Compaq CV 7500 17" CRT Monitor
Volume control has to be at highest volume to hear TV
there is something wrong with your TV speaker, and that's why you have to increase the volume to the highest to be able to hear it.
The TV speaker needs to be changed in order to enjoy the TV volume well again.
Take care.
Apr 12, 2010 | Televison & Video
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
My volume is not working correctly. I have it turned up to 100 - the highest and I can barely hear it.
Monitor volume is affected by TWO volume controls (or even three...)
1: Volume on the monitor can be set to 80%
2: Main Volume on the COMPUTER can be set to your liking.
3: Wave volume on the computer mixer settings should be set for 80% (See Sound on your control panel or right click your volume control near the clock)
If all these are right and the volume is still low, check that the audio is not set for surround 5 or 7 channel and the monitor audio connector is plugged into the REAR green connection on the computer.
Still problems, the audio driver in the monitor is shot.
Dec 05, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
My monitor keeps popping up in Chinese. I want to turn off the pop-ups and/or change the language to English. Can you help ?
This MAY help......
Download:
http://downloads.emachines.com/userguides/8510632_Web_en.pdf
Page 11. Select "Advanced" on the OSD setting to change the language.
Please rate this response if you find it helpful. Thank you.
Feb 22, 2009 | E-Machines eMachines Monitor E15T4
Sound Stuck on High
change the audio ic it has a short within.this will restore your set to normal dont forget to make checks in that same circuit as there might be resistors,diodes or caps that had contributed to the failure of the ic.good luck.
Aug 03, 2007 | Toshiba 19A25 19" TV
Samsung LN26A330J LCD TV Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
