Question about Toshiba 37LX96 37 in. LCD TV/DVD Combo
Not powering on and disc light is flashing - Toshiba 37LX96 37 in. LCD TV/DVD Combo
Why is my Sony bdvn790 stuck on bd/DVD and the front light flashes
I am having the same issue. From what I can tell (at least in my case), there was a disc stuck in the DVD drive. I had to dismantle the chassis, remove the drive and manually "eject" the disc. There is a manual screw port under the BD/DVD drive that you turn and it will manually eject the disc. However, removing the disc from the drive did not solve my problem. I am still getting the BD/DVD displayed when powering the system back on and the light is flashing as you described.
Oct 12, 2014 | Sony Bdv-n790w 5.1-channel 1000w Blu-ray...
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
The power on my ps3 does not stay on it powers on then cuts off immediately and the power light keeps blinking red and a bluray disc is stuck inside it will not release the disc
you have a yellow light of death if you look closely there is a yellow flash before it turns red the disc can be removed when its fixed as it needs to be serviced ok sorry to be bringer of bad news :(
Jan 13, 2011 | Sony Playstation 3 (PS3) Console
Flashing red light
it would make a goooooooood trafic light
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
Power icon flashes
Generally when the power icon flashes, it means the disc tray is opening. try opening and closing it after you start it up.
Mar 03, 2009 | Microsoft Xbox 360 Console
Will not open nore will it power up
try unpluging for a few minuits, and plug back in. if that does not fix problem it has a bad power supply and needs to be repaired or replaced.
Jul 30, 2008 | kawasaki SVP500 Multi-disc DVD Player
Panasonic Camcorder
thats an indication that no disc or wrong type of disc is present. Have you tryed to clean the laser lens>> or using the approved lens cleaner for this unit?? try it and see you may be surprised. good luck
Apr 25, 2006 | Panasonic PV-DV53 Mini DV Digital...
Toshiba 37LX96 37 in. LCD TV/DVD Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
