Question about Medion md40298 Notebook
Akoya E7212 problems starting stop C00000006 instruction@0X%P referance memory @0x %P. the required data was not placed into memory because of an I/0 error status of 0x%x
Laptop starts up and then this come up : stop C00000006 instruction@0X%P referance memory @0x %P. the required data was not placed into memory because of an I/0 error status of 0x%x
2 Suggested Answers
  • 94 Answers
SOURCE: Touchpad on my Medion Akoya
if there is any light in keypad then double lik in light to unlock key pad
Posted on Aug 25, 2011
The error says "Application has generated an exception that could not be handled. Process id=0x (a series of numbers that change), Thread id=0x (numbers that change). Click OK to terminate the applica
did you add any new hardware or software just before this error started. If this is a Windows PC you can go into the safe mode and remove the bad software. You can also (if you can) remove or disable the hardware. Reboot into the PC as normal and see if you are still getting the error.
Jul 31, 2013 | Computers & Internet
Tip
0x error
No matters which printer you are using if you get any error like 0x*****
please please donot perform any steps...please call HP teach support on 1800-474-6836...and if its needed they will replace the printer..
on Jan 21, 2010 | Office Equipment & Supplies
The application failed to start last time.Do yoy want to reset to factory defaults and lose all your POIs,tracs and settings yes no application navi.exe has performed an illegal...
That 0x number is a base memory address in your computers memory. I would save all my data and reinstall the program since it looks like a corrupt program or registry entry is causing it to fail. It should not be a big deal.
Jan 17, 2018 | Yugo Cabrio Cars & Trucks
STOP:c0000005 The instruction at 0x%081x referenced memory at 0x%081.The memory could not be %s. This message appearing on laptop screen - cannot do anything with it now!
There are a lot of cause to this error message. But mostly software. If you back up your files. I suggest to perform factory image recovery and restore the computer to factory default setting.
Jul 21, 2010 | Dell Inspiron 6000 Notebook
My Dell 1525 has a blue screen when switching on, says config_list_failed, I've switched it off & back on but just says the same, Technical information at the bottom says ***stop: 0x00000073 &...
from these errors, the hard drive is full and the system is out of virtual memory which is gotten from the pagesys, you need to get a new drive,, a blue screen is crash if you have a windows OS
Mar 09, 2010 | Dell Inspiron 1525 Notebook
Blue screen of death
Hello
Well, that spesific error mesage is because of a hard drive failure. I notice that this same problem occurs more in portable devices, such as laptops. The thing is, that if the laptop was droped during the days previous of this error, the mechanism will still run but the disc will have so many bad sectors that you will not be abvle to use it anymore.
I would suggest that you try formatting the drive first and see if it works, otherwise get a new drive. Hope this can help you.
Best regards
Andrea
Nov 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Blue screen appears have to run in safe mode, dell inserion laptop with vista
The blue screen error will have a code something like 0X******** (0X*******............). You can either comment the error code here or you may also check the same in the microsoft website. It will have a solution as well.
Good luck !
Aug 28, 2009 | Dell Computers & Internet
A problem has been detcted and windows had been shut down to prevent damage to your compuetr
This is a windows stop error. Are you running windows XP?
If it is the first time you have seen it you can try restarting and it may never appear again. If it does:
At the bottom of the screen you will see some text saying STOP ERROR: 0x000000?? (0x???????? 0x???????? 0x???????? 0x????????)
Look at the code prior to the brackets 0x000000?? - write it down and google "STOP ERROR 0x000000??".
This will let you know what is causing the STOP error. Very common reasons for this are component reseating required and disk-checking. You can run a diskcheck through the Windows Recovery Console (can be installed to hard-disk - simplest way is to install combofix and follow the onscreen instructions - or run from your windows installation disc).
Jul 23, 2009 | Dell Dimension 9200 PC Desktop
Can't get past bios post
If you can't even pass the POST your only option is attempt to flash the BIOS. Go to your motherboard manufacturer's website to find updated BIOS and instructions for your particular board.
Apr 08, 2009 | Acer Computers & Internet
My acer aspire 3690 reboots while trying to install XP SP2
ive heard of this problem happening often with ms vista and nvidia video cards try going to nvidia website and make sure you have the latest drivers
Feb 04, 2009 | Acer Aspire 3690-2196 Notebook
Medion md40298 Notebook Logo
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
