Question about Futaba Toys
How to bind futaba R606FS receiver for my helicopter
She won't fly ?
First thing is to read manuals. A lot of RC's you have to bind or connect signals of the receiver and hand held controller. This is called binding. You always turn on radio first and then the RC. To bind there might be a button recessed in the receiver you need to push (you might need a small tool or stick) to push it. Most of the time it will go from a flashing light to a solid green light.
Jun 01, 2014 | Syma s33 3 channel rc helicopter 2.4ghz...
Front led light just blinks
Make shure transmitter is on and ready BEFORE powering heli and let rest the heli without any mouvement while and after powering up ( gyro setup ). Receiver maybe need to be bind for it to work, look for binding procedure in manual.
Nov 24, 2013 | SWANN Micro Attack Military Blue Gyr
My helicopter 9053 will not connect to my controller
The receiver is not binding to the transmitter. Make sure the batteries are in good shape in transmitter. I'm assuming it's a 2.4GHz radio frequency.
When you are about to fly, turn transmitter on first after 4-5 seconds turn
heli on or plug battery in on heli. In the manual there should be a page describing radio binding. It will describe on what gimbles to move and
in certain sequences to complete the process. When the light on transmitter stops flashing means the binding process is complete.
Hope this helps.
Dec 15, 2011 | xheli 9053 Outdoor Volitation Metal...
T2er no information on how to charge batteries
YOU SHOULD HAVE A CHARGING UNIT WITH 2 LEADS 1 IS A JACKPIN THAT PLUGS INTO THE TRANSMITTER THE OTHER LEAD HAS A CONNECTOR SIMMILAR TO THE BATT TO RECEIVER IN THE HELI IF YOU HAVE A REMOTE CHARGING SOCKET IN THE HELI JUST PLUG IT IN. IF NOT DISSCONNECT THE BATT FROM THE RECIEVER AND CONNECT DIRECT TO THE BATTERY
Aug 18, 2011 | Futaba 6CH Digital Transmitter and...
Need a mnual, unable to locate mine
You can get the manual on the link below. If that is not you radio please give the correct model #.
http://manuals.hobbico.com/fut/6exh-manual.pdf
Apr 17, 2011 | Futaba 6CH Digital Transmitter and...
I have just bought a kds 450 sv helicopter and when i turn it on and plug it in it just beeps and a red light flashes on the kds800 gyro .nothing else happens any help with this would be greatley...
Me too i just boight one with the flymentor built in and same it just been and nothing happens, ive tried everything re binding but the binding been not to be working either it says to connect the jumer to the bind pins and it will flash red but it doesent?
Any help would be great same as the guy above...
Thanks in Advanceds....its just a nice awniment at the moment....
Feb 17, 2010 | Air Hogs Havoc Heli Helicopters
Throttle goes wide open
Its is probably a faulty potentiometer in the transmitter's throttle channel. Take it back to the store if possible otherwise see if you can get another transmitter and bind it to your helicopter. The binding process will be in your instruction book.
Feb 28, 2009 | Esky Flight Simulator R/c Helicopter Kit
Toys Logo
70 people viewed this question
Top Futaba Toys Experts
ray gallant
Are you a Futaba Toy Expert? Answer questions, earn points and help others
