Question about Rancilio Silvia Espresso Machine
Rancilio silvia trips circuit breaker
Every time I turn it on, it trips the circuit breaker of whatever circuit it is plugged into. This is true even when nothing else is plugged into the circuit. It also tripped 3 different circuit breakers that work perfectly with other appliances.
    Scholar:
  • 24 Answers
There is an electrical short within the machine, ...don't doubt it - the results of your experiments prove that it has an electrical fault and that your tripping circuits are doing exactly what they should to keep you and your property safe.
The machine needs servicing by a registered Rancilio electrician, don't go inside yourself, its highly likely that the part causing the tripping is dangerous and will need to be replaced.
Posted on May 27, 2014
4 Suggested Answers
  • 1089 Answers
SOURCE: Upon turning on the Rancilio Silvia, it trips the
Hi
Sorry to say but your boiler element is ruptured and needs to be replaced. You can do an ohms check across the element terminals and if its good you will get a reading of 12 to 16 ohms.
Posted on Oct 15, 2009
  • 100 Answers
SOURCE: My Rancilio Silvia Espresso Machine trips a
Your element is burned out ship it to us www.dolcevitaespresso.com
Posted on Feb 04, 2011
coffeefixer
  • 53 Answers
SOURCE: I have a Rancilio Silvia
use a voltmeter and check if you have continuity across the element terminals,(do this with macine unplugged and terminals off element. this will happen if something has cauased the element to fail. or check if you have a leak on top of boiler that is shorting out aomething.
Posted on Sep 16, 2011
How do you reset the thermostats on the rancilio?
Safety thermostat for rancilio silvia is on the boiler and has a red button on top.Press this button down and you should be ok.
Other thermostats cannot be reset - just replaced.
If the boiler temperature exceeds 165 degrees Celsius, this thermostat will trip, cutting power off from the element. This is done to try to prevent element damage due to overheating.
Mar 25, 2014 | Rancilio Silvia Espresso Machine
I have a Rancilio Silvia Espresso machine and its tripping the circuit breaker in my kitchen, any advice as to what i can do to fix this problem
Sep 16, 2011 | Rancilio Silvia Espresso Machine
Pops circuit breakers
Hi
If it pops the circuit breaker, most likley your element is shorted. You will have to replace the element.
Apr 11, 2011 | Rancilio Silvia Espresso Machine
Why has my rancilio silvia v3 steamer stopped
Remove the top panel and check the 3 thermostats there, one of them tripped.
Jul 16, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
May 29, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Upon turning on the Rancilio Silvia, it trips the house breaker switches. Have moved to different outlets and does same thing. Had been working ok previously. Thanks.
Hi
Oct 13, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Keeps tripping the Breaker
Usually when that happens there is a problem with the element in the boiler.
Jul 06, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
476 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
