Question about Garden
Spark plug gap simplicity 516 rt tiller - Garden
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
SOURCE: trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
Posted on May 18, 2009
  • 81 Answers
SOURCE: Left my 5 hp tiller out in the rain..now no spark to plug.
There is a gap between these two parts. I always just used a dollar bill to gap them and it always worked. .010 is the proper gap.
Posted on Jun 22, 2009
rwvanlue
  • 486 Answers
SOURCE: what is the spark plug gap on the Mantis 2-cycle
0.030" will work
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 12, 2009
  • 2468 Answers
SOURCE: what is the spark plug gap on the 2 cycle mini
.030
Posted on Apr 02, 2011
I have a cub cadet rt 65 tiller it has a gc190 honda it has no spark new plug i have also put a new coil disconnected the kill switch and still no spark
Was it a genuine Honda ignition unit? as i have had bad after market units, check the air gap between the flywheel and the unit this should be around 0.3 mm, finally remove the cutout wire completely from the coil and try for a spark again.
Apr 11, 2018 | Honda Garden
Have an old troy bilt tiller, spark plug gap for tecumseh engine
Hi Jesse:
SPARK PLUG AIR GAP ON ALL MODELS IS
.030 (.762MM)
NOTE:
Not all spark plugs have the same heat range or reach. Using an incorrect spark plug can cause severe engine damage or poor performance. Tecumseh uses all three of the reaches shown.
Ta Da!
Mar 13, 2016 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
What is the coil gap to the flywheel on a Bolens BL410 21A-121R965 tiller
A safe gap is the width of a business card
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Nov 27, 2015 | Garden
What is the spark plug gap for tiller ?
-Not. the gap has nothing to do with NO Start.
-Possibly bad coil.
Good luck
Mai
Jun 01, 2014 | Craftsman Garden
Mantis will not start - has good fuel and new sparkplug
Check spark plug gap and functionality of throttle. I all is OK it could be flooded. If flooded. Remove spark plug and pull cord a helf a dozen time to clear it out. Replace plug with correct gap and start her up! Gap is .035-040 inches. If you don't have a guage, 40 thou is about 1/6".
May 21, 2010 | Mantis 2-Cycle Tiller
Jun 22, 2009 | Garden
What is left to do but change the flywheel?
check what they call air gap between the coil and flywheel .010-.012 gap
also be sure your flywheel is in time.
you will actually have to remove it to do this and check for the sheared key or be sure the key way aligns with the crankshaft keyway on the flywheel
May 17, 2009 | Mantis 2-Cycle Tiller
Spark plug not sparking
The points are set at 20 thousands.If you installednew ones you may have to use a fine point file to clean them a little sometimes they put a coating on them to keep them in storage ,the armature has a gap of 10 thousands you can use an index card to set these.
May 05, 2009 | Mantis 2-Cycle Tiller
I have a brand new mantis 2 cycle tiller which won't start. I don't believe I'm getting a spark through the plug. Does anyone know what the gap should be for the sparkplug?
when trying to test for spark. remove it from the cylinder hole. attach it to the plug cable (the part that normally attaches to it but you had to take off to remove the spark plug) then hold it to any steel part of the engine or a table... try not to shock yourself. that method does work, but it isn't good for you, especially if you have an unknown heart condition. if there is no spark, check the gap. usually about .2, and then try again. if there is still no spark you may need to check the timing and armiture on your engine.
Mar 07, 2009 | Mantis 2-Cycle Tiller
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
