Question about Toshiba e-Studio 4540C Multifunction Color Copier
Change default to black and white - Toshiba e-Studio 4540C Multifunction Color Copier
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
How to change to the default from colur to black and white on Bizhub series C35
Ok, it's been a while but here's what I remember. If your talking about default black and white COPYING, try the following. First set the machine to make B&W copies, then hit utility and go to user mode, touch current settings, then OK. B&W should now be the default.
Mar 14, 2011 | Minolta bizhub 350 Black and White Copier
How do I program the printer to only print in blck/white
Any default (or normally used) settings, can be made by changing the Printing Preferences for that specific printer.
1) Find the printer...ex: [Start]--> [Settings]--> [Printers and Faxes]...then [right-click] on the printer name/icon.
2) The pop-up menu that appears should list an option to select called, "Printing Preferences".
3) Under the [Paper/Quality] TAB, you can select "Black and White" (instead of the normally default, "Color").
4) Make sure to click OK, and that printer should (by default/ normal) print in B/W now.
--- you can change this to "Color" in Print Setup...but it is temporary for that printing job, and should revert to it's default state, afterwards.---
-Printing Preferences- is where any changes you make will become the Normally used setup.
.Hope this helps
Mar 10, 2010 | HP DeskJet 932c InkJet Printer
Our project is giving only black and white. It
reset the settings to factory default. if you have a dlp projector, replace the colorwheel. but you'll need to send it in for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 20, 2009 | Sharp Office Equipment & Supplies
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 05, 2009 | HP Deskjet 3845 InkJet Printer
Reseting the default settings
set printer to black and white, press utility, user settings, save and select current settings then press set, should work
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
Toshiba e-Studio 4540C Multifunction Color Copier Logo
49 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
