When the machine has started it clicks , light flases on front ,
Door locks then nothing. i cleaned out the filter and swiched off at the main then tryed again but still nothing
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
FO6 E01 error code on Whirlpool Duet washer
go online whirlpool support ..they can tell u quick by the error code it displays..but I had Samsung last week do very same thing it was off balance sensor..good luck..and once you get sensor very easy to put new sensor in..
May 22, 2016 | Whirlpool Washing Machines
De error but the machine have not door switch
if its front loader door swich is there,,but toploader no door swich but with main pcb having sensor,,locking with door lid with megnet,,,
Feb 08, 2014 | LG Washing Machines
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
Won't drain or spin. after disconnecting power and resetting I set it to drain/spin and start. It clicks, a little water goes in, It clicks the door locks, it clicks the spin light comes on but nothing...
Clean out the pump filter and see if that helps.
SERVICE MANUAL
NOTE: Use the manual as a guide for replacing component. Use your machine's tech sheet for diagnostics then party on!
Mar 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
HE3 no error codes, will not start when button is pushed. All mode lights are on push any wash cycle and no go. Checked water lines, drain line, no obstructions. When you push the wash cycle button it...
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Feb 26, 2011 | Kenmore HE3T Washer
Whirlpool Duet Washer GHW9150PW1
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Mar 04, 2009 | Whirlpool GHW9150 Front Load Washer
Door won't open and no error lights
sounds like the door interlock is manfunctioning.
Jan 19, 2008 | Zanussi FJS1225W Front Load Washer
Cleaning
I am not familiar with this machine's model, but in most of the machines the filter is located under the panel in the bottom of the machine (the panel under the front door). You should pull the panel out and you will find the filter there. Before openning the filter prepare a bowl and a floor cloth to avoid water's flooding. Good luck!
May 06, 2006 | Hotpoint First Edition WMA22 Front Load...
Washing Machines Logo
Top Washing Machines Experts
