Question about Miller Welding Tools
How to wire buzz box to miller HF 250-1
I HAVE BEEN GIVEN A MILLER HF 250-1 TIG UNIT THAT I WAS TOLD I COULD WIRE TO MY STICK WELDER FOR POWER.
CarlGehrke
  • 169 Answers
SOURCE: I have a miller dynasty
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Posted on Dec 02, 2008
CarlGehrke
  • 169 Answers
SOURCE: miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Posted on Jan 26, 2009
  • 7 Answers
SOURCE: Miller TIG Welder Syncrowave 350XL has no digital read out...
it's free for you to download.
http://www.millerwelds.com/products/tig/syncrowave_350_lx/
Posted on Mar 21, 2009
keemo68
  • 1263 Answers
SOURCE: miller Syncrowave 250 / no tig arc start
seems that you have a ground issue. make sure the ground clap is on barte metela and secured tight. make sure your tungsten electrod is about 1/8 of an inch form the edge of the cone. you will find that you will get a faster arc this way.
Posted on Apr 19, 2009
  • 24 Answers
SOURCE: Need wire diagram for Miller Syncrowave 250 DX
diagram is on the inside of cover or go to Millerwelds.com
Posted on Sep 18, 2009
Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
Nov 21, 2013 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
Miller syncrowave 250 tigrunner with gas flow
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Nov 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Jun 21, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Miller welder CP250TS
You don't say why you need schematics. Most of the stuff that you need to know to install, use, and understand the welder is covered in the operator manual. You can get one at this web page.
There is also a copy of the schematic diagram on the inside cover of most Miller welders. Please be careful if you're not familiar with high current power supplies, you could get hurt pretty badly in the blink of an eye.
Regards,
Carl
Jan 17, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Dirty weld
clean your metal with a good peace of the green scotch guard scrub pad prior to the weld.Also try turning up your gas and move a little faster when using filler wire,rember to much heat causes a darker dirter weld.hope this helps
Dec 28, 2008 | Welding Tools
Welding Tools Logo
213 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
