Question about Kenmore 30-Pint EnergyStar Dehumidifier
When I turn on the dehumidifier, the humiditiy setting is 01 and will not run nor let me change the setting...red bucket full light flashes but no water in bucket
All lights are on, will let me change settings with timer and fan speed but not humidity level. stuck on 01
  • 3 Answers
SOURCE: Kenmore 54701 (70 pint) dehumidifier stopped running
the lowest setting for % of humidity is 35% on that unit... sounds like with all the other errors that the IC board is bad (the Control circuit board behind the displays)
Posted on Dec 04, 2007
  • 184 Answers
SOURCE: Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Posted on Dec 19, 2007
  • 52 Answers
SOURCE: Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
Posted on Jun 09, 2009
bozcro
  • 867 Answers
SOURCE: Kenmore Dehumidifier Model 580.52650 Says "Bucket Full" - Wrong
the problem is with the switch which is connected to the float arm, try pulling it manually, it shoud turn on and off your unit if working properly
Posted on Jun 14, 2009
SOURCE: Bucket full light flashing but not full, humidity % shows as 01%
I posted an extended answer to this problem with part replacement info and pictorial. Why hasn't this solution been posted???
venasguy@comcast .net
Posted on Mar 04, 2010
RED BUCKET LIGHT FLASHES OFF & ON HUMIDITY SAYS 01 NOTHING HAPPENS
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 13, 2011 | Dehumidifiers
Bucket full light flashes, humidity setting won't change - only says 01
heatman101
Jun 07, 2011 | LG LHD459EL Dehumidifier
Bucket full light flashing and 01 in RH display even though it is set at 50%. Turned unit on and off and it did not reset it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Sep 01, 2010 | Kenmore 54701 Dehumidifier
Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
May 09, 2008 | Kenmore 54701 Dehumidifier
Nov 25, 2007 | Kenmore 54701 Dehumidifier
Jan 09, 2007 | Kenmore 54501 Dehumidifier
Kenmore 30-Pint EnergyStar Dehumidifier Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
