Question about Kenmore Refrigerators
My side by side ref ,when it goes on the lights flicker,
When it goes on also it makes like a click sound, two or three with in 2 seconds apart.but other then that it works just fine.
  • 478 Answers
Check conderser coil,or all of unit. If problem persist, you'll need a thee in one start assist kit.
Posted on Mar 11, 2009
Screen blinks and then goes out. tap on side and causes flickers
sure sounds like loose solder joints, look for them in the deflection circuit, just find the hard plastic encapsulated body with the thick red wire sticking out of it thats where usually the loose solder joints develop.
Sep 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
Continuous clicking sound and light flickers with each click
Replace the main board (mother board) WR55X10656 behind the panel on the back side of the refrigerator.
May 30, 2009 | GE Profile PDS22MBS Bottom Freezer...
No picture, audio flickers on and off
Jan 30, 2009 | Televison & Video
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Ge ref. making clicking noise not running display not working
Replace the main board on the back my was about a $130 at a wholesale parts store and i put it in
Jan 17, 2009 | GE GSH25JFR Side by Side Refrigerator
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
RCA hd50lpw42yx2 not working
There are 4 1000 mf. 35 V caps. on the AC IN pwb. (power supply) that are chronic fail items. After back is off, slide the chasis on the left side back toward you. Slide about 1/2 inch and it will lift out of track and then the chasis will be more accessible. The said caps are the tallest on the bd. and 2 are located side by side on the bottom front of the chassis. The other two are side by side about an 1 1/2 above the other 2. Most likely the top of the caps are pooched out. Replace all 4 whether they look bad or not. Problem solved
Jan 23, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
No picture, no sound?!?!
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
Dec 12, 2007 | Samsung PCN5425R 54" Rear Projection...
Refrigerators Logo
74 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
