Question about Cosco Alpha Omega Convertible 22-150
Safety Harness straps
I cant figure out how to get the safety harness straps to go in right in the car seat.
  • 9 Answers
SOURCE: Cosco 5-point omega carseat
You might be able to contact Cosco for a manual or diagrams of where everything goes or replacement parts, there info is: Consumer Relations Department at 1-800-544-1108 Hours of operation Monday ? Thursday 7:00 AM to 6:00 PM EST and 7:00 AM to 4:30 PM EST on Friday.
Posted on Jul 19, 2007
  • 48 Answers
SOURCE: Converting to a Booster Seat.
Better yet, please use this manual for clear instructions and dont forget to leave a rating for me. Thanks!!!
Posted on Jan 25, 2008
  • 4 Answers
SOURCE: Cosco Alpha Omega
You can call the manufacturer, Dorel Juvenile Group, at (800) 219-0509, and they will advise you what to do. A carseat with twisted straps is not safe, especiallyif they involve the harness.
Make sure you also check to see if your AOE is one of the ones recalled for harness issues; if so, the Dorel Juvenile Group will send you a free repair kit.
Posted on Aug 26, 2008
  • 3 Answers
SOURCE: took seat apart to wash, can't figure out how to
I would look on the car seat and find out what company makes it or a phone number for them. They might be able to walk you thru how to relace the straps or most companies will send you a new manual for free (might have to pay S&H)
Posted on Apr 15, 2009
  • 20 Answers
SOURCE: Someone removed all harness from my Cosco, Summit
My daughter has a car seat just like this one, and I wash it about once a month so I hope I can explain this detailed. First, at the base there is a metal rod that will need removed. When you take this rod out the base and seat will seperate. Set base aside and turn seat upside down. Take your strap and put an end into each slot. Turn seat over and pull your straps even. Put the two black pieces for your latch on (one on each side) then put you chest pieces on and run straps thru slots on back of seat. Turn seat around and make sure the straps go OVER the silver bar in back (this allows you to adjust shoulder height) Secure to the metal piece that runs to front for tightening adjustment. Sey seat back on base and replace rod. Hope this was helpful.
Posted on May 08, 2009
  • 45 Answers
SOURCE: I need instuction on how to reassemble safety
Here are the links to download Cosco carseat instructions:
Posted on Mar 25, 2010
0 characters
1 Points
Need new straps for maxi cosi tobi
Hi Mandy
Due to the safety implications of a carseat harness being incorrectly fitted we are unable to supply a harness to you as a spare part item.
To replace the harness the carseat would need to come in for our engineers to provide replacement and safety checks to ensure product is working as per specification. 1924a6a3-e420-4f10-b6df-f9a1deebe867.jpg
Apr 05, 2013 | Maxi-Cosi Priori
How to remove maxi cosi priorfix harness straps
Hi Deirdre
Due to the safety implications of the harness in your carseat being incorrectly fitted we must recommend that you do not attempt to remove or replace the harness yourself.
Should you wish to have it replaced you can send the seat to our engineers for inspection and replacement of the harness plus safety checks to confirm that it is working as per specification. 5bac1756-b7e9-4806-aa74-da8d8a038fa4.jpg
Mar 22, 2013 | Maxi-Cosi Priori XP Booster Car Seat -...
How to remove maxi cosi cabrio harness straps
The harness of a carseat should never be removed or replaced by anyone other than a trained engineer due to the safety implications of it being incorrectly replaced.
The carseat fabric should be removed from this carseat and they can be washed - the harness itself should be cleaned in place in the carseat using a solution of stain remover and water and a small scrubbing brush or hard scourering pad to clean the harness. Excess water in the carseat should be dried immediately and thoroughly to prevent any parts rusting. Loose crumbs can be removed using a vacuum cleaner.
Alternatively the carseat can be sent in for the engineers to replace with a new one. Inspection and single repair (replacement of the harness) plus safety checks and courier collection and repair can be booked for 39.99GBP if you're in the UK by calling 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Mar 22, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi. I have a Maxi-Cosi Priori SPS Car Seat which I purchased three years ago. I struggled to dismantle the straps from the seat to get the cover off in order to wash it, but I did manage it. But now I...
Good Afternoon
The harness straps should not have been completely removed from the carseat - you do not have to do this in order to remove the fabrics for washing. We cannot advise that you re-thread the harness yourself due to the safety implications of it being incorrectly done. This carseat should be sent to our engineers for them to carry out this work and for full safety checks to be done before it is used again.
If you are in the UK please contact our customer service department on 01284 413 141 Mon-Fri 8.30-4.30 and have a chat with one of the advisors about this.
Aug 21, 2011 | Maxi-Cosi Priori
Cannot refit maxi cosi car seat straps after washing
Hello - The harness straps of any carseat should not be removed as the re-threading of them requires specialist tools. Due to the safety implications of the harness being incorrectly re-fitted, the carseat would need to be sent to the engineers for inspection and repair as required. If you're in the UK please contact the customer services department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss.
Aug 13, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
The straps have got dirty and need washing or replacing - houw do i remove the straps
Good Afternoon
The harness of a carseat should not be removed due to the safety implications of it being incorrectly fitted. The harness can be washed in situ with warm soapy water.
Alternatively you can book it in for the harness to be replaced by calling the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. Standard charge is 72GBP and will include courier collection and delivery of the item.
Jul 01, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I really need to take the straps off our maxicosi cabriofix car seat, taking the cover off has never been a problem but i cant work out how to remove the shoulderstraps
Hi Emily - You should never remove the harness from the carseat due to the safety implications of the harness being incorrectly refitted. To wash the harness straps please remove the fabric only and wash the harness in situ using a warm water solution with lemon juice and bicarbonate of soda to clean it up .
Feb 12, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I dissasembled the car seat so I need get manual in order to re-assebly the belts in the correct way , can you help me
I just noticed my car seat had a safety recall back in 2007 and noticed you had the same recall on the 22150. I just ordered a new kit from Cosco (which was free) to replace the faulty parts. Here's the recall notice ans website to go to:
Click on "Harness Adjustment Strap Inspection" and give your info. to order the kit.
News 8/30/2007 12:00:00 AM
Dorel Juvenile Group Announces a Voluntary Safety Recall of the Harness Adjustment ******** Certain Cosco®, Safety 1st® and Eddie Bauer® Brand Child Restraint Systems
Columbus, IN August 30, 2007- Dorel Juvenile Group (DJG) is issuing a voluntary safety recall for certain Cosco®, Safety 1st® and Eddie Bauer® brand child restraint systems manufactured during November 2003 through December 2005. Although no injuries have been reported, there is a potential for the harness adjustment strap to loosen during use. If this were to occur, the harness may be loose around the child, possibly increasing the risk of injury in a crash. We feel that it is important to replace the harness adjustment strap.
Model numbers affected are:
Cosco®: Alpha Omega®, Alpha Omega EliteTM: 22150, 22155, 22180, 22269; Eddie Bauer®: 3-in-1, Deluxe 3-in-1, Deluxe Convertible: 22740, 22750, 22755, 22756, 22757, 22770; Safety 1st® : Alpha EliteTM, Alpha Omega®, Alpha Omega EliteTM, Alpha SportTM, InteraTM, EnspiraTM: 22151, 22450, 22451, 22452, 22453, 22455, 22460, 22480, 22481
The model number and date of manufacture may be found on a sticker located on the side or back of the child restraint system.
DJG will contact all registered owners and provide them with information on how to obtain a free repair kit to replace the harness adjustment strap. Those consumers who have not registered their product should visit or call 800-219-0509 to order a free repair kit. The affected seats should not be returned to the retailer.
DJG encourages parents to obtain and install the repair kit as soon as possible. Parents may continue to use the child restraint system as directed in their instruction manual. Parents should be sure to adjust the harness adjuster strap snugly each time they put their child in the child restraint system. If there is any difficulty adjusting the harness adjustment strap, or it does not remain tight, DJG suggests using a different child restraint system until the repair kit has been installed.
To check for harness slippage:
(1) Fully tighten the harness, (2) pull on the harness straps without pressing or lifting the harness adjustment lever. If movement occurs, the harness is experiencing slippage.
Jul 04, 2010 | Cosco Alpha Omega Convertible 22-150
How to change the Safety 1st "Alpha Omega Elite" to a booster
To change it into a belt positioning booster seat, you remove the harness straps completely and use the positioning clips on the side of the carseat (up by the head) to position the automobile's seat belt to the appropriate position.
Apr 18, 2010 | Safety 1st Alpha Omega Elite 22456 TTN...
Cosco Alpha Omega Convertible 22-150 Logo
20 people viewed this question
Top Cosco Baby & Toddler Car Seats Experts
Level 1 Expert
Are you a Cosco Baby and Toddler Car Seat Expert? Answer questions, earn points and help others
