Question about Craftsman Garden
Need the valve setting for a ys4500 twin cam kohler engine
Kohler lawn mower 597cc engine twin cam need valve clearance specs
  • 653 Answers
SOURCE: Engine tappet clearances
According to http://freespace.virgin.net/tommy.sandham/databook.htm# Rocker Adjustment, the cold clearance is .008" intake/.018" exhaust in the non-GT 1500cc, and .012" intake/.022 exhaust on the GT. Sweet little car!!!
Posted on Mar 01, 2009
stevenhurc
  • 450 Answers
SOURCE: torque specs for big ends, mains, cam caps
found local Adelaide engine reconditioning shop that knows all about g200 twin cam EFI isuzu motors for parts and engine components ( pistons, rings, bearings etc. ) and machining, Chris Milton engine reconditioning. They will do machine work for me so then i can put it together.
Posted on May 27, 2009
  • 73 Answers
SOURCE: valve adjustment
tiburon uses hydrolic lash adjusters there are no valve lash adjusting If you hearing a pecking sound on the top of the mtr try some oil additive or replace the hydrolic lash adjusters
Posted on Jun 15, 2009
rburroak
  • 14 Answers
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
Posted on Jun 19, 2009
  • 376 Answers
SOURCE: what type of oil does a OHV 17.5 HP Kohler engine; number of zerk
10w-30 oil. The only grease fittings I know of are on the front wheels and axles.
Posted on Jun 22, 2009
How to adjustvalves on kohler22 on craftsman
Gary, they may be hydraulic and not require adjustment, check the attached links, they will help determine and show how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://outdoorpowerinfo.com/engine_specs/kohler_valve_clearances.asp
How to Adjust the Valves or Valve Lash on Kohler Courage XT Lawn Mower...
Work on the Cub Cadet i1046 Kohler twin setting the valves
Owners Service Manuals
Apr 14, 2016 | Cars & Trucks
Set timing of crank and cam shafts on a Kohler K161 engine
Since there different versions with and without gears it is best to read and following the instruction in the service manual.
Kohler K91 141 161 181 241 301 321 341 Service Manual pdf Google Drive
Oct 25, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How to test engine coil on 19 hp kohler engine
Get yourself a test spark plug for small engines
There is a small engine one & one for car with HEI
Ignition
Looks like a spark plug with an alligator clip on it
Look on the internet for one similar to KD 2757
Has to be for small engine & std ignition-- not electronic
ignition systems
Oct 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Set valve clearance on 21hp briggs and statton
Valve clearances are set by either tappet screws in the lifters or on a lot of small engines, clearances must be set by either cutting out valve seats with a special cutter tool (to DECREASE clearances) or grinding the end of the valve (to INCREASE clearances) and generally are from .008-.010 on intake valves and .010-.012 on exhaust valves. Check engine specs to insure proper clearances.
Sep 24, 2014 | Garden
What would be the cause of a Kohler 25hp twin, backfiring through carb from one cylinder
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
Jun 16, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I'M UNABLE TO DOWN LOAD THE INSTRUCTIONAL COURSE MATERIALS
that engine is junk... ask your question, I know all to well about those things. as for the manual, cant help there as what I see being Kohler Expert Certified is different than what you see
Dec 21, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Can the overhead valves on a 16hp sears craftsman with a kohler engine be the reason why it won't start and if so, can I adjust them
Valve clearances will also effect the decompression valve in the engine, if they are too wide the valve lifter will not work and the battary will not have enough energy to crack the engine.
Jun 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Fuel keeps coming out of the carb
replace the needle valve in the carb the fuel we get now melts the seal off the valve then change the oil
May 20, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Do you not know how to reset governor
go to youtube they have videos on how to adjust governor
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Garden Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
