Question about Konica Minolta DiALTA Di200 Copier
Error code F34 on Konica 1015 copier is there any way to fix without service call?
No...it's a fuser error (low warm up temperature)...It's a blown fuse, or lamp, and the code can only be reset in 'service mode'after fixing the fault
Posted on Mar 12, 2009
2 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Posted on Mar 14, 2009
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
Our Konica #2125 is displaying a F34 error code. what can we do to fix this?
this code for fuser unit but make sure about this code is that's f34-1 or f34-2
anyhow you need to rest this code
Aug 30, 2010 | Office Equipment & Supplies
I have a Konica 7145. It has error code
This is a fixing unit over temperature fault. The device has detcted the fixing unit has gone over 470 degrees F.
You will need to check the Thermisters in the fixing unit, and repair or replace as needed.
Service mode DIP Switch needs to be reset after repairing.
WARNING
• When F34-∗∗, F35-∗∗ or F36-∗∗ (fixing temperature related abnormality) occurs, be sure to repair a defective part before setting the 25 DIPSW 3-1 to 0.
If the 25 DIPSW 3-1 is set to 0 without repairing a defective part, it may cause a fire.
Apr 26, 2010 | Canon imageRUNNER C3200 Copier
How do you clear F34 code on a Konica 1312?
Hello sir; Just follow the steps to removed the error code;
press "enlarge" and "reduce" keys simultaneoously, and hold for 5 seconds, then press 0 within 2 seconds, now enter 25 press start, reset to 0 press start. turn power off and back on.
Sep 16, 2009 | Konica Minolta Office Equipment & Supplies
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
Error code p27
this is a toner density failure code if the service company replaced the developer and did not run the density adjustment it will through this code or it could be an older firmware version you need at least level 16 or it could be a bad toner sensor i would recomend having them come back out to fix it
Apr 05, 2009 | Konica Minolta Office Equipment & Supplies
Description:
Solution:
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Nov 29, 2008 | Office Equipment & Supplies
Konica 7020 f34-4
need to rest code 25 mode dip switch 3-1 should be 0
hope that help
let me know if you need more help with access
Sep 01, 2008 | Office Equipment & Supplies
Konica 7145 Fuser Error F34-2
You could go into service mode and reset error count normally to get into the service mode is the following depending on age of machine.
Thanks Jason
A. Procedure
1. Press the Utility/Counter key.
2. Touch [Details] on Meter Count display.
3. Press the following keys in this order.
Stop → 0 → 0 → Stop → 0 → 1
Aug 16, 2008 | Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
357 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
