Question about Garden
What is the UT-08106 homelite yark sweeper spark plug gap
  • 10865 Answers
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Posted on Feb 07, 2009
  • 120 Answers
SOURCE: homelite ut08107 will not fire. no spark at plug.
It may be the coil if there is not any spark. Or a wire could off at the coil. One more thing it could be is the spark plug wire may have came loose from the coil. These a few thing to check.
Posted on May 05, 2009
  • 246 Answers
SOURCE: What is the spark plug gap setting for a homelite
Hello mackoshark:
Most Small Engines Use a .035in to .040in Plug Gap.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
panilling9
  • 284 Answers
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
Posted on Jul 05, 2009
  • 583 Answers
SOURCE: Homelite Textron chain saw UT 10403A ...need
25to 1 and .025 thou
Posted on Aug 06, 2009
Homelite chainsaw ut 10516 won't start have replaced all electrical parts still no spark why?
Incorrect gap on ignition coil? On/off switch stuck in closed position and grounding out spark?
Mar 30, 2017 | Homelite Garden
What is the spark plug gap for a homelite BP 250 gas blower
Not sure of the book value but I always use .025 to .028 gap on the plug and it runs fine. Hope this helps.
Jun 30, 2015 | Homelite Garden
Spark plug gap for homelite textron ut 10080c chain saw
Hi idone8...
Set your gap using a round feeler gauge to .28 to .32
Please take time to rate me
Sep 08, 2011 | Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite ut 10695 spark plug gap, gas oil ratio?
Gap the plug at 0.020", and the fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil, fresh fuel, and mix in it's own container (don't make up more than a gallon at a time unless your business is sawing). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation. Hope this helps!
Nov 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
WHAT SPARK PLUG SHOULD I USE IN MY OLD HOMELITE CHAIN SAW UT 10045A??
Champion CJ6 according to your IPL.
Find "SXLAO Chain Saw UT-10045-A" here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 01, 2010 | Garden
No spark superxl ut-10045-c
The following are givens:
1. You replaced the spark plug with a known good one and the malfunction persisted.
2. You did something similar to the following in an attempt to isolate defective parts and you concluded the ignition is not producing spark.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
I found your saw "SXLO Chain Saw UT-10045-C" by following the instructions here:
Both the solid state ignition and condenser (most likely failures, but no promises) are NLA at the authorized site, part numbers are still valid. An Internet search for "Homelite YourPartNumber" displays many sources other than eBay.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 03, 2010 | Homelite Garden
Spark plug gap
Jul 05, 2009 | Homelite Mighty Lite Lawn Trimmer
Spark plug gap
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
