Question about Garden
Husqvarna hu775h spring dislodged - Garden
My machine won't stop running when turned on
Since you turn it on and it starts to run without your help the foot control has a problem. Try to pull the control apart and turn it on again. It is likely the spring is either broken or dislodged from where the bracket is. Check the spring.
Aug 13, 2015 | Husqvarna Sewing Machines
Fuel system Husqvarna HU775H
Add cleaner to the fuel and use the machine. Then add stabilizer to your gas can before filling it. Modern gasoline goes stale after 30 days. Gas will form varnish in your fuel system if left for extended periods causing various degrees of problems up to preventing the machine from running at all. Gas stabilizer is absolutely required for out of season storage or you risk a carburetor clean and rebuild.
Jul 25, 2014 | Husqvarna Garden
Husqvarna Mower HU775H 175cc briggs and stratton engine won't start
check for spark if there sqiurt sn omestarting fluid in carb if starts rebuild carb
Jul 04, 2014 | Garden
Why is the pull start locked?
broken cable or bad spring
May 31, 2014 | Husqvarna Garden
My HUSQVARNA HU775H will not start. I just replaced the spark plug and still nothing.
are you saying it wont even allow you to pull starter out ? if this is so , then remove the spark plug completely and try if it still wont pull then seems it was overheated and now piston is fused to cylinder wall , if it does allow u to pull it , ck your reed valves in head seems there not releasing when they should also have a look at rope in starter it could be all twisted up keeping you from pulling it out as well
Mar 08, 2013 | Husqvarna Garden
Need to find a repair manuel for a husqvana model hu775h
Remove the blade. Remove the plastic cover by removing the bolt on the underside and two bolts on the top of the deck. To get the belt off, you will need to remove the bolts from the plastic shroud in front of the drive, rotate the drive downward to access the two bolts holding the metal plate that prevents the belt from coming off the pulley. Then you can remove the belt.
I found that my belt was so worn that it would come off the main drive shaft.
Hope this helps.
Jun 30, 2012 | Husqvarna Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
