Question about Dell OptiPlex GX110 PC Desktop
System Does not start
Hi, No Display on my PC (Optiplex GX110) , there are no beeps. Though the green power led is on, but thrs no activity on other led (which I presume is for HDD), I tried to check the Processor (and I presume its work its working fine), RAM is also OK. but thrs no display. I am not able to go to bios also. Worse thing is thr are no beeps, so can't make out the problem. If anyone out thr could help me sort it out, or atleast tell me wht problem to look for. reagrds, Sukhjender
    Scholar:
  • 42 Answers
There is a full step-by-step guide to diagnosing this problem on the dell website (actually very helpful). You can find it here (titled Dell? OptiPlex? No Post, No Video for GX100 and GX110): http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=DFB8C72540D611DCACF8FBE14C494B1F&treeid=9F6F166431914C6B9722AA3209A42250&Query=dHJvdWJsZXNob290&SystemID=PLX_PNT_P03_GX110&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
Posted on Aug 02, 2007
  • Quinten van der Werf
    Quinten van der Werf Aug 02, 2007
    BTW, I have seen this problem before when a USB printer has been turned on before the computer is turned on. I believe it has something to do with the BIOS trying to interrogate the USB device to detect if it is bootable (on a printer which incorporates a card reader).
    If that doesn't apply to you, the Dell wizard runs through the following steps:
    1. Step one asks if the power led is on solid green. Click on next.
    2. Step two asks you to make sure the computer is not in manufacture mode (most likely not, so click next again).
    3. Step three asks you to disconnect all external equipment (printers, modems etc). I have seen USB printers cause this problem when they are switched on before the computer.
    4. Step four asks you to remove all expansion cards (any cards that are installed on the motherboard).
    5. Step five asks you to diconnect all drives and remove the memory. Do you get any error beeps when turning on the system at this stage?
    The wizard then branches off at this stage depending on your results. If no codes, it asks you to reseat the processor. If there are beeps, it asks you to reinstall the memory one stick at a time.
    I suggest you follow it through and heopfully resolve the issue soon. Hope this helps!
Dell optiplex gx110 beeps
Sounds like you got some bad RAM remove them blow the dust out with some compressed air and the put them back one at a time. Try each stick in both slots. Hope this helps.
Aug 26, 2017 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
My desktop Dell optiplex gx110 won't start.only solid orange light.
try to repair your oparating system please use the second repair option
Dec 07, 2009 | Dell OptiPlex GX110 PC Desktop
Dell Optiplex GX110 will not come on when I press button but i hear clicking sound is there any way I can fix this problem?
A gx110 is pretty much uneconomically repairable. If the system is powering on, getting video but not booting, then the clicking is likely the hard drive. Of you are not getting any video, then post what the Power LED and the diag LEDs on the back of the tower indicate.
Oct 04, 2009 | Dell OptiPlex GX110 PC Desktop
Data is not sent to the monitor
The first thing to do is to pay attention for "beep" when your press the power button (or the reset button) to turn the computer on or reboot it. The beeps that a PC makes tells you a lot about the state of your computer. I couldn't quote for you the exact beeps to listen for, but your manual for your motherboard may tell you. Different beep pattersn tell you what is wrong with a computer.
I think for many common motherboards it is something like 4 beeps to tell you the graphics card has failed. Don't quote me, but that is at least along the lines of how it works if not the exact number.
If you're getting no display after starting your computer make sure you hear one beep. Then, listen for other activity. If you're computer has a floppy drive, listen for the 'floppy seek'. Otherwise, listen for hard drive activity. If it sounds as though there's activity along those lines but still no signal/display on the monitor perhaps check the cable between your PC and the monitor. Never hurts to just make sure the monitor is turned on of course.
If your monitor is on, and the cables are connected securely I wold restart the computer again and check for the beeps. I would be certain to count them and check the manual. Your graphics card may have failed if you hear abnormal beeps (more than one as one is usually the healthy indicator). If you hear no beeps then the PC is not even getting in as far as testing it's devices and could quite possibly be a motherboard failure.
Dec 19, 2008 | Dell OptiPlex GX110 PC Desktop
System does not start
The beeps are error codes and if you listen carfully you will hear a pattern of short and long beeps. If you can identify the pattern we can help you figure out whats going on....
Feb 14, 2007 | Dell OptiPlex GX110 PC Desktop
Try pressing F2 or Del to get into bios and see if the system time and date are correct. if not the cmos disc shaped battery found on the motherboard may need replacing. You can also reset the bios by locating the 'JBAT1' terminal on the mobo and put the jumper cap from pins1-2 to pins 2-3 for a few seconds, then back across pins 1-2 again, and reset time and date next time you boot up the pc. Although, i recon the continues beep noise can refer to a processor fault but trying the above is the cheaper first step to take, good Luck
Dell OptiPlex GX110 PC Desktop Logo
157 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
