Question about Trane TZEMT400BB3NX Home Energy Management Thermostat with Nexia Home
Trane TZEMT400BB3NX manual - Trane TZEMT400BB3NX Home Energy Management Thermostat with Nexia Home
Operating manual for trane sfhc40
this is all i could find to do with what you are looking for so not sure if this link will help you out.
manual for trane sfhc40 Google Search
Dec 15, 2016 | Heating & Cooling
I moved into a home that has the Trane Comfortlink IIXL950 thermostat. How do I reset the pass code?
Pages 17 and 19 appears to indicate the password is your Wifi SSID passcode
http://www.bayareaservice.com/wp-content/uploads/2011/12/TZONE950-Owners.pdf
checkout the other pages for WEP support and other advance settings for multi zone and schedules
Aug 17, 2016 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Feb 06, 2010 | Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Hooking up a used 550 to a new 80% trane UD-R9V,
In this situatioin you'll eed a second transformer 110volt to 24 volt to relay from w to common to operate only when furnace being called for.
Feb 07, 2009 | Aprilaire 550 Humidifier
Trane TZEMT400BB3NX Home Energy Management Thermostat with Nexia Home Logo
226 people viewed this question
Top Trane Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Trane Heating and Cooling Expert? Answer questions, earn points and help others
