Question about Nec Display Solutions NP-P350W LCD Widescreen Entry-Level Professional Installation Projector
My NEC P350W projector is turned upside down - Nec Display Solutions NP-P350W LCD Widescreen Entry-Level Professional Installation Projector
I have an nec mt850, my picture is upside down...how do i fix that?
Unit is probably set for ceiling mount or reverse screen projection. In the options menu there will be settings to alter it back to normal aspect.
Apr 28, 2012 | NEC MT850, MT1050, MT1055, MT1056...
The ceiling mounted projectors image is upside down, how do i turn it the other way?
Go to the menu, in the "Setup" section, then go to "orientation"..and select "ceiling"...image will invert for you.
Good Luck
Aug 12, 2010 | NEC MultiSync VT580 Multimedia Projector
Picture is upside down
Many projectors allow you to vertically flip the image for mounting the projectors upside down. Each projector is different in how to change that setting, so I would look in your owners manual.
Mar 09, 2010 | NEC MultiSync LT84 Multimedia Projector
NEC NP1000 projector: In a corporate meeting...screen display is upside down! Help?
There should be a menu setting to flip the image vertically. Check the menu settings.
Feb 04, 2010 | NEC NP100 Projector
Image upside doen on philips data projector
go into the menu under settings and change the image from ceiling to front.
Jan 06, 2010 | NEC VT47 Multimedia Projector
I mounted my In Focus Projector upside down because of the ceiling mount I bought for it. Now the picture is upside down. How do I fix this?
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
Sep 28, 2009 | NEC VT465 Multimedia Projector
Data Projector projecting upside down
If you go onto your menu and click on "setup". Press orientation and select the right one for your projector. It allows you to choose whether your projector is on a table top or ceiling mounted etc.
Feb 10, 2009 | NEC VT47 Multimedia Projector
Upside down picture
YOU most likely have the thing mounted upside down that all
just flip and check the instructions
>if it is hooked up through a pc you will have to change the settings in on the pc( graphfic/diplay) ROTATE 90degress
PLEASE be kind if i helped and post more if you need help RATE this userKindofcheap
Aug 31, 2008 | NEC VT465 Multimedia Projector
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
Image is upside down on projector
in amodel nec projector vt490 the status lamp is blinking or flashing and the machin not work
plz send me the problem and solusion.
Oct 28, 2007 | NEC LT20 Multimedia Projector
Nec Display Solutions NP-P350W LCD Widescreen Entry-Level Professional Installation Projector Logo
222 people viewed this question
Top Nec Display Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Nec Display Office Equipment and Supply Expert? Answer questions, earn points and help others
