Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
2910 ford tractor white smoke out ex - RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
2 Suggested Answers
  • 3600 Answers
SOURCE: my ford 6600 tractor has white smoke white comes
If you have white smoke it is a head gasket or water jacket. If their is no water in the oil on the dip stick tube and you can crack the oil drain plug and don't get water coming out then it is most likely a intake gasket thats leaking. You did not mention if it was a L head or H head that Marks a difference on where the water can leak.yo could have a bad head gasket and have water leaking into one cylinder, to test this go to a tractor shop or truck shop and buy a grease pencil that is heat sensitive mark each exhaust pipe with the pen then start the engine if you have one cylinder that the grease does not melt that will tell you that that cylinder has an issue, cold be a injector copper a head gasket or broken head bolt this will give you an ideal of what your up against and how much you are going to have to spend before you get a lot of money into it.If you need more help just post to tis answer and thanks for using fix-ya.
Posted on Mar 17, 2010
Tractor has been stood, had new head gasket but smokes white smoke and loses power when warm. What is wrong with it.. Any ideas..
Run a radiator pressure test or test for carbon monoxide vapor in the radiator. You have a cracked head or block if the head gasket was installed correctly. Note the installation would include measuring the block and head for warp.
Aug 31, 2016 | Ford Cars & Trucks
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
The engine burns white-blue smoke.
i am guessing this is a gas engine on a farm tractor. White/blue smoke is usually a sign of burning oil. Depending on the color, it can also mean you are burning oil and water both. You could have bad rings, bad gaskets, or cracks in the head or block.
If there was a problem with too much gas from the carb, (flooding), then the smoke should be black.
Sep 03, 2011 | John Deere 420,1020,2010,2020,2510,2520...
What does the P0405 do and what does it look like on the eng. smoke out of the ex.white
P0405 = EGR valve issues - replace your EGR valve. RE: white exhaust - check door water in your oil, white exhaust usually means a blown head gasket (white smoke is usually steam)
Mar 27, 2011 | Ford F-150 Cars & Trucks
My ford 1210 tractor is blowing black smoke. I've
your injectors are set to rich
Jun 06, 2010 | Garden
When running tractor has white smoke coming out of exhaust and it smells like fuel. the owner before me just put a new head on it. don't really know why but he did. the carburetor was also just rebuilt.
White smoke out the exhaust is a sign of water burning or getting into the exhaust system and steaming out. It is possible he got the head gasket on wrong or it has blown another head gasket. I would run a compression test on each cylinder. You can get a screw in compression tester at my auto parts stores that will screw into the spark plug hole. It will come with instructions also.
I know this doesn't fix your problem but it will help you get started in isolating it.
Jun 06, 2010 | Ford 8N Tractor
My ford 6600 tractor has white smoke white comes out, but theres no smoke coming out into deep stick and and engine oil inlet,sometimes the engine is shut down emmidiately, injector is already...
Mar 17, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
It was throwing white smoke out of ex now it dont run
In my experience, white smoke is oil burning. Question is Why?
Could you have put too much in the engine? You might have broken rings. You at the very least have fouled plugs now. Clogged crank case vent?
Check the oil level and adjust as appropriate. Rings is a big deal. Plugs are pretty cheap and easy to change.
I hope this helps you solve your trouble.
Thanks for using FixYa.com
Positive comments welcome
a
Oct 26, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
