Question about Honeywell QuietCare HCM-630 Humidifier
Fan works, but no mist and water isn't going away
My humidifier fan works just fine, but mist no longer comes out therefore the water just stays at the same level as it's not being used to create mist. I changed the filter in December so not sure that is the problem. Any ideas? It's only a year old.
  • 478 Answers
Turn on furnace and urn up humidistst to call for it. Tube from solenid to the filter should have water running if water is up to the valve and solinoid is opening . It should be warm to your touch., Using an ohm meter you can sheck the coil it shuold have continuity.
Posted on Mar 12, 2009
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
Dec 29, 2015 | Holmes Sunbeam SCM3501 Cool Mist Console...
Lights on but no fan, no mist
"Take the humidistat out of the humidifier and look for the 3 slits below the restart button, take a hair dryer and send some warm air into those slits for 5 minutes. That usually recalibrates the humidifier."
Feb 06, 2014 | Honeywell QuietCare HCM-6009 Humidifier
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
Family Care cold mist humidifer
cool mist humidifiers don't put out any mist. only the warm ones do. now if you put your hand over the area where it's coming out for about 2 minutes and take it away your hand should feel damp. almost clammy. if it feels like that the unit is working fine. so your not doing anything wrong. if you have any other concerns please let me know.
Mar 13, 2009 | Family Care HM1555 Humidifier
Runs, but nothing comes out
Check the filters and the fan blade it may have come loose. Do you still hear the motor running? Get me the model number on the unit. Sorry it took so long to get back to you I have been sick the past few months.
Aug 30, 2008 | Bemis 526 300 Humidifier
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
No water vapor coming out
You might need to check either the water level sensor or make sure that there aren't any deposits on the nebulizer. I just posted the following sections from the manual for another problem:
- Ensure that water level sensor is assembled properly. (I scanned a page from the manual that shows how to dismantle and reassemble the sensor: here)
1835 Ferry Road
Jan 19, 2008 | Crane Pig Humidifier
Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Dec 31, 2007 | Sunbeam Ultrasonic 81696 Humidifier
Honeywell QuietCare HCM-630 Humidifier Logo
463 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
