Question about Peugeot Vehicle Parts & Accessories
Peugeot expert van 2.0 hdi x reg not starting, what could it be?
  • 345 Answers
SOURCE: peugeot expert 2.0 hdi heater problem, fan working ok, no heat
check the water pump
Posted on Feb 07, 2009
SOURCE: peugeot expert 20 hdi
Hi, I have a 2.0HDI Expert which was doing the exact same thing as yours, blowing thick black smoke, sluggish and loss of power on gradients, a hissing sound and surging. I replaced the air flow meter but that didn't help. I was told to replace the turbo but a turbo expoert told me not to as it would blow white smoke if it was faulty. I was then told to replace the injectors but a diagnostic test showed them to be functioning fine. I was then told to look at the intercooler which had thick sludge at the lower left pipe. I replaced it today - Sunday 12th July and it is now driving like a new van. It now pulls me up gradients with ease in 4th and 5th instead of having to drop gear to get to the top. I got a replacement from Euro Car Parts for £147 inc VAT. To tell if this is your problem, look through the gaps in the lower section of the bumper at what looks like the radiator and look for sludge over the inside of the bumper and all over the pipe where it joins the back of the radiator (intercooler). Also open the bonnet and look down behind the grille for the same sludge. Hope this sorts it for you. Barry, Newtownards, Northern Ireland.
Posted on Jul 12, 2009
SOURCE: heater fan not working
if i turn on fan it stops and starts and stop and starts
Posted on Nov 02, 2009
SOURCE: peugeot speedo mileage counter and speedo dont
Had this problem on mine & the main dealer were stumped. Eventually found it myself after a lot of pocking about.Have a look at the wiring loom in the engine compartment. Looking under the bonnet look closely on the right hand side of the engine above the gearbox where the wiring loom passes from the rear of the engine over a metal bracket/support to the front. The loom has a tendancy to rub against the bracket and eventually damage the cables within. You will have to remove the air filter canistor & a few air hoses to get to the bracket. Good luck!
Posted on Jan 11, 2010
  • 4088 Answers
SOURCE: peugeot 406 hdi electronic immobiliser warning
The ignition key may be defective or in need of a battery to generate the code needed to disarm the immobilizer. Hope this helps!
Posted on Mar 05, 2010
How to fit alternator to Peugeot 306 hdi 2.0?
start by removing all plastic covers,wheel,inner fender lining,serpentine belt and tensioner and the headlight to gane access
Nov 06, 2015 | Peugeot Cars & Trucks
Can't find code to unlock radio/CD player on Peugeot expert hdi van 53 plate make of player is peugeot
53 plate Pug will not require a code - it uses car's VIN coded into radio internal memory. This can be done by anyone with lexia/proxia/Peugeot Planet diagnostic interface.
Feb 08, 2014 | Car Audio & Video
Hi, i have a x reg peugeot 206 hdi, the serpentine belt snapped, i have a new 1 but cannot find a diagram on how to fit it. please help.....i need my car!!
Peugeot 206 1.4 HDi - DV4TD (8HZ) 2004 ...
1. The serpentine belt routing diagram - without A/C (Air Conditioning)
2. The serpentine belt routing diagram - with A/C (Air Conditioning)
Sep 18, 2011 | Peugeot 405 Cars & Trucks
I need some liquid to stop my van making noises
It's not the transmission, because you wouldn't see the space that the transmission fluid fills, and it's doubtful that it's the brake fluid, the brakes will act up all the time (stop lights, etc) if that were the case, so it must be the powersteering fluid. If your car is sort of a pain to steer around corners, the slower you go, the harder it is to move the wheel to turn, and you hear a sort of whiney noise when you get into a deep turn, or are turning slowly, that would for sure be powersteering.
May 29, 2010 | 1987 Peugeot Liberte
PEUGEOT 206 HDI STARTING PROBLEM
your ecu monitor.. emissions control unit mod is done! i dont think this is a cheap fix. either wait for warmer weather,, sell the car or find a dealer to fix this diesel puppy...word of advice .. dont buy peugeot in this country .. or any country...joke.!!
Feb 26, 2010 | 1989 Peugeot 405
2005 peugeot expert 2.0 hdi turns off?
Sounds like a flakey connector - try hunting down all the connectors you can find under the bonnet. Separate them, spray with WD40 and reconnect. Start at the engine management computer (silver block with fins on and lots of wires coming out). Take great care not to bend pins.
Jun 08, 2009 | 2006 Peugeot 505
How do you remove the heater matrix on a peugeot expert
window wipers off remove trim and there is 10 mm nuts, remove them, remove speedo cluster and radio etc, there is 2 10mm bolts below each end in footwells at end bottom of dash, 1 bolt below your ash tray in front of gearstick, u got to get gear stick surround out.
Mar 30, 2009 | 2006 Peugeot 604
Peugeot expert 20 hdi
Jul 11, 2008 | 2006 Peugeot 604
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Peugeot Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Peugeot Vehicle Part and Accessory Expert? Answer questions, earn points and help others
