Question about Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
Xerox 3635 email setup
My Scan to email stop working and is not sending any emails. I know it must be a setting. Internet is working fine.
  • 2072 Answers
SOURCE: how do i activate scan
The Scan to E-mail feature provides the ability to scan and send a document as an e-mail attachment.
NOTE: The Scan to E-mail Kit is required to enable the Scan to E-mail feature. The kit contains a License Agreement, installation instructions, and a password.
You must be a System Administrator to perform this solution.
To enable the Scan to E-mail feature:
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm]. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Common Settings]. The Common Settings screen will be displayed.
  7. Select [Maintenance / Diagnostics]. The Maintenance / Diagnostics screen will be displayed.
  8. Select [Software Options].
  9. Select [Keyboard].
  10. Enter the password contained in the Scan to E-mail Kit using the keyboard on the Touch Screen, and then select [Save].
  11. Select [Reboot]. The machine will automatically power OFF, and then power ON.
  12. Enable the Scan to E-mail port settings. See the Related Items below. After the port settings have been enabled, the E-mail option will be displayed on the Touch Screen.
Posted on Jul 30, 2008
  • 2072 Answers
SOURCE: Xerox scan to network
What is the model number? That is not a fault on an M15 which this question is listed under. Have you checked your LDAP settings to see if something there has changed?
Posted on Mar 13, 2009
  • 2072 Answers
SOURCE: Xerox Workcentre 4150 having problems setting up Scan to Email
  1. Print a Configuration Report. See the Related Items below for additional information.
  2. The following fields should be set as indicated for scan to e-mail to be properly enabled and set up:
    1. Under the Installed Options section, Email field: Installed / Enabled
    2. Under SMTP Setting section, SMTP Host Name or SMTP Server IP Address field requires a valid entry.
    3. Under SMTP Setting section, Default E-mail Address field requires a valid entry.
If the WorkCentre is a network connected configuration, it will arrive with the E-mail service enabled. The copier-only model is not network connected and cannot perform Scan to E-mail.
NOTE: E-mail is enabled at factory, by default. If the E-mail button is not available on the All Services screen, enable E-mail in the Tools mode.
Before starting the setup procedure, make sure the following items are available or have been performed:
  • Make sure the WorkCentre is fully functioning on the network. See the Related Items below for additional information.
  • E-mail service must be available (enabled).
    NOTE: E-mail is available by default.
  • Make sure the TCP/IP protocol is set up and the HTTP protocol is enabled on the WorkCentre; both protocols must be fully functional.
  • Obtain the IP Address of a functional SMTP mail server that accepts inbound mail traffic. See your Network Administrator for additional assistance.
  • Make sure the DNS settings are configured correctly and obtain the Domain Name address, if applicable. See your Network Administrator for additional assistance.
  • Create an E-mail account which the WorkCentre will use as the default 'From' address.
  • Test the E-mail account by sending an E-mail to the WorkCentre account. This task should be completed at a mail client on your network that supports SMTP.
To access E-mail settings using Internet Services from a web browser window:
  1. From a computer, open the CentreWare Internet Services (CWIS) window. See the Related Items below for additional information. The main CentreWare Internet Services window will be displayed.
  2. Click [Properties], click [Connectivity], click [Protocols], and then click [TCP/IP].
  3. Enter the Domain Name in the Domain Name field. For example, type: abc.xyz@company.com in the field.
    NOTE: It is only necessary to configure the DNS settings if Host Names are to be used.
    If Dynamic Addressing has been set on the WorkCentre (DHCP or BootP) the Domain Name will not be accessible. To be able to access the Domain Name, select [Static] from the IP Address Resolution menu list.
  4. Scroll to the bottom of the window and click the [Apply] button to implement any modifications.
  5. When prompted, enter the current Tools mode information in the Username and Password fields.
    NOTE: The default Username is 'admin' and Password is '1111'.
  6. Select [SMTP Server] from under the Internet Services Protocols section.
  7. Select either [IP Address] or [Host Name] and then enter the Host Name, or the IP Address and Port Number (1 - 65535) of the SMTP Server. The default Port is 25.
  8. Place a check mark in the Server Requires SMTP Authentication check box if required.
  9. Enter the Login Name and Password.
  10. Click on the [Properties] tab. The Properties window will be displayed.
  11. Click [Services], click [E-mail Settings], then click [E-mail Setup]. The E-mail Setup window will be displayed with the following list of options:
    • Scan Resolution
    • Attachment Type
    • Output color
    • Date / Time stamp on PDF documents
    • 'From' and 'To' Security Options
    • Auto send to self
    • Specify default Subject field text
    • Specify default Message Body text
    • Specify default Signature text
    • Programmable SmartKeys
    • Choose E-mail / Fax Forwarding rules
    • Choose Confirmation Sheet rules
  12. After making any required selections, click on [Apply
Posted on Mar 31, 2009
  • 2072 Answers
SOURCE: LDAP lookup fails on Xerox WCP4150
I would check your software version. Several of the older versions had a lot of LDAP problems.
You can print out a system report and find your Firmware level, then go to Xerox.com, go to Drivers and Downloads and see what the new version. Current firmware level is 10.100.46.000 . follow the instructions.
Posted on May 12, 2009
  • 64 Answers
SOURCE: xerox 7232 workcentere cannot send emails
Judging from what you've said, I would say this is a setting on the printer. You need to make sure you have the outgoing address correct. Basically go into your printer settings with your E-mail server IP's.
Posted on Jul 17, 2009
09-800 on phaser 3635 xerox how to fix
That error indicates an incompatible toner cartridge for that model. Verify you are using oem Xerox toner.
Dec 21, 2015 | Xerox Phaser 3635MFP/X Multifunction...
Scan email bizhub c450
All you have to do is login into web access go to network setting and change the setting according to your new provider.. I my opinion SMB works better it easy to setup.. All you need is a shared folder and login info of where u send the scan to it can be setup from the web access as well
Nov 21, 2013 | Office Equipment & Supplies
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
I can't configure the email. I enter the SMTP address but wet I try to connect tell me Conn. Failed , I don't now how to configure it and where if is i have to put the information about my internet...
SMTP2Go has an SMTP server that works with Xerox WorkCentres:
http://www.smtp2go.com/blog/smtp-server-for-xerox-workcentres/
You can also test their service for free.
Sep 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Getting Scan to email to work on the Xerox workcentre M118? We use a go daddy webmail for work and we are trying to get the scan to email to send the emails to us?
you have just to active "send email" protocol, reboot machine and put ip adress of smtp server on the correct location in machine user interface and if your webmail need authentification you should create an account in your server and put them under smtp server on machine user interface.
good luck
Aug 26, 2010 | Xerox WorkCentre M118 Black and White...
Copystar CS-1820 Black and White Copier: need to scan a document to send as an attachment t...
You need to setup the email server setting through the command browser of the machine. open the explorer and type the ip address of the machine. under Email scanning setup the email server info and you will be fine.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
May 17, 2010 | Kyocera Copystar CS-1820 Black and White...
Sending mail with Vista Windows Mail
Window Vista also have Outlook Express.. please enter the full info for your email account..
On the E-mail Settings page, enter your email account information as follows:
Your Name
Enter your first and last name.
E-mail Address
Enter your email address.
Account Type
Select POP3.
Incoming mail server
Type for your incoming mail server.
Outgoing mail server (SMTP)
Type for your outgoing mail server.
User Name
Enter your email address again.
Password
Enter the password you created for your email account.
After this please check for "Test Account setting"
If everything is working fine, then remove the previous account
And let us know the error message if come up any.
I hope it will resolve the problem and you will be able to use the Outlook.
May 01, 2009 | Microsoft Computers & Internet
    • Scan Resolution
    • Attachment Type
    • Output color
    • Auto send to self
Mar 31, 2009 | Xerox WorkCentre 4150 All-In-One Laser...
Scan to email
Scan to email needs an IP address or the SMTP server name and the port. Now it depends if you use an SMTP server or are you just at home? Normaly the SMTP port is 25. The SMTP server could be the one you use in your email account as well. Something like mail.upc.ie. If you dont have a SMTP server you cant set up scan to email.
Aug 29, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer Logo
313 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
