Question about Car Audio & Video
I'd like to replace my passenger side front door 6.5'' speaker.
It has blown. I have removed the screen and unscrewed the screws but the speaker still seems solidly in place. What am I to do next? Robert.
  • 36 Answers
The speaker may seem still attached because the magnet may be stuck to the door, also they sometimes use a type of weatherseal that makes them stick, try prying it away with a paint scraper or flat bladed screwdriver.Good luck and please rate this answer,thanks.
Posted on Apr 10, 2009
2004 honda accord ex how to remove pasenger side front speaker
You must remove the door panel (apply gentle pressure around several points between panel and door, end removal of at least one screw in the inside door handle). Once the interior panel is removed, there are several screws holding the speaker in place. Remove these screws and the speaker (once disconnected from the wiring) will come out.
Jan 15, 2014 | Vehicle Parts & Accessories
I need instructions, written and hopefully with photo examples, that will teach me how to replace the passenger side mirror on my Ford Sport Trac. The truck is a 2004 model and the mirror is motorized...
Removal and Installation
NOTE: LH door is shown, RH door is similar.
  1. Disconnect the battery. For additional information, refer to Section 414-01.
  1. Remove the front door window control switch panel and trim covers.
    1. Remove the door screw cover.
    1. If equipped with power windows, remove the door window control switch and disconnect the electrical connectors.
    1. Remove the door handle bezel
3. Remove the door handle screws
  1. If not equipped with power windows, remove the screw and the window regulator handle.
  1. Remove the screws and the front door trim panel.
ganyapr_4.jpg6. Remove the door speaker Remove the screws.
Disconnect the electrical connector.
Remove the door speaker.
7. Disconnect the exterior rear view mirror electrical connector
8. Remove the nuts and the exterior rear view mirror.
Feed the power mirror wiring through the opening in the front door.
9. To install, reverse the removal procedure
i hope that this could help you
Feb 20, 2011 | Ford Explorer Sport Trac Cars & Trucks
How to remove passenger side front door panel to replace that speaker?
Feb 20, 2011 | 1996 Buick Skylark
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Power window failure, 1998 jetta vr6 glx, driver side does not work and passenger side only goes down from drivers switch. also how does the trim panel come off to work on the door
Remove the little door nob thingy for lock and unlock it just screws off,, Then you have 6 Allen key bolts around the door trim, remove those. Then remove the door handle cover just pops off you may need a small flat blade screw driver. you have two big screws Philips head screws in there... Then remove your speaker cover then the speaker, then remove the speaker, then remove the speaker bracket, then lift the door panel out. The motors and the regulators for your windows are **** door man makes a good unit for them i replace all 4 of mine... They are expensive is the best price i could fine. Looked for 2 years in junk yards and posted adds for replacement parts don't wast your time its damn near impossible. cost me about 500 for the 2 front window motors and regulators and I only replaced the regulators on the back windows I think they were about 50 a peace.
Jun 28, 2010 | 1998 Volkswagen Jetta
How do I replace speakers on a 1994 xj6 ?
Replacement of Front and Rear Door Speakers
Required Tools:
#2 Phillips Screwdriver (magnetic tip is useful)
9 mm Nut Driver
8” or 10” Flat Tip Screwdriver
Small awl or other sharp pointed instrument
Soldering Iron w/solder or 8 to 10 small wire **** splices
8 to 10 small machine screws -- #8 x ¾” or equivalent 8 to 10 small machine screw nuts & flat washers to match
Thread locking compound “Loctite” (optional)
6” wooden dowel of ½” diameter to be used as a drift
Small mallet or hammer
1) Whenever you are attempting to a remove door panel to gain access to the speaker, or any other electrical component, absolutely disconnect the negative battery cable. Battery power is supplied to each door window motor and it’s always prudent to de-energize these circuits before you attempt any panel work.
2) XJ40 door inner panels (front or rear) are comprised of an upper and lower section, which interface to provide complete inner door coverage. Neither panel is difficult to remove nor are any specialized tools required.
3) Remove the Upper Inner Door Panels as follows:
It’s a good idea to store all the removed parts and screws in the adjacent foot well for safekeeping and easy access when you are putting everything back together.
a) Using a small awl (or equivalent), remove the small “square” plastic cover for the inner door lock release mechanism (upper right side when facing inner side of door). It pivots towards the front of the car.
b) Using the #2 Phillips screwdriver, remove the inner door lock release mechanism plastic / chrome escutcheon. It’s held in place by a single machine screw. Pull out on the door lock release mechanism and the escutcheon is easily removed.
c) Using both hands, pull out on the wood veneer panel at the inner door lock release mechanism to provide clearance and slide the panel towards the front of the car. The panel is secured on the left side by slip-in clips and they release easily.
d) Using the #2 Phillips screwdriver, remove the two sheet metal screws on the left side. For the front doors only, lift the bottom of the rubber ventilation boot at the front edge of the door and remove the sheet metal screw. Additionally, for the front door only, use the large flat screwdriver as a lever to ease out the single “fir tree” type press-fit connector. Neither of the rear doors contains these two additional fasteners.
e) Using both hands, lift the upper inner door panel until it releases from the metal ridge along the window line. It doesn’t take much effort to remove the upper panel as it slides off vertically. Store it on the seats for safekeeping.
4) Remove the Lower Inner Door Panels as follows:
a) Using the #2 Phillips screwdriver, remove the sheet metal screw located at the upper edge of the lower panel.
b) Using a ½”small wooden dowel or equivalent drift, place it under the lower edge of the door handle screw access cover. Lightly tap each end of the access cover using the dowel and mallet in an upward direction to release the access cover. These covers can be tight if they have never been removed in the past, but they will release.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw located in the middle of the door handle.
d) Using a small awl or equivalent, remove the bottom door light lens by releasing it from its locator at the rear and sliding it outwards from the door.
e) Using the #2 Phillips screwdriver, remove the lower panel securing sheet metal screw located in the middle of the bottom door light assembly. All sheet metal screw fasteners for the lower panel are now removed.
f) Using both hands (and the large flat screwdriver, if needed), carefully pull off the lower inner door panel by release the series of fir-tree type press-fit connectors along the sides and lower perimeter. Once the panel is removed, it can be laid horizontally on the seat as there is sufficient length of wire bundle to allow this movement. It is not necessary to disconnect the wiring harness, but if desired, the connectors can be released so that the panel can be moved to another more worker friendly location.
5) Remove Door Mounted Speaker as follows:
a) Disconnect the speaker positive and negative conductors by releasing the electrical connector.
b) Using the 9mm Nutdriver, remove the speed clip nut from each of the four (4) speaker fastener studs. Press the nutdriver down firmly to engage the speed nut … do NOT cut away any foam material as it is not necessary.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the left (driver side) or right (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
d) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately above the speaker. It is located just below the upper sheet metal screw securing tab on the lower panel … the screw was previously removed in Step 4a.
e) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower right (driver side) or lower left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
f) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower far right (driver side) or lower far left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
g) Steps 5c, d, e and f will release the speaker / window lift pushbutton panel from the lower door inner panel. Removal of the sheet metal screws will allow the speaker panel to be pulled away from the lower panel by 3” to 4” to facilitate access for speaker removal.
h) With the speaker / window lift pushbutton panel eased back for working clearance, grasp the speaker with one hand while pressing the four (4) speaker studs downward through the foam supporting material. After the studs are clear from the foam material, the speaker can be removed from the panel.
6) Install New Door Mounted Speaker as follows:
Typically, base XJ40 models use 3.5” door speakers while the VDPs will use 4” door speakers. Though I believe it is possible to mount either type in either model.
a) Using the wiring supplied with the new speakers and insulated solderless **** splices, transfer the old speaker wiring electrical connector to the new speaker. Another alternate method is to simply solder the old speaker wires with connector to the new speaker terminals. This is a superior method for electrical continuity and strength of joint … although it does require some soldering skills.
b) Install the new 3.5” speaker by easing back the speaker panel and sliding in the new speaker. Normally, the 3.5” models will mount with only two fasteners.
c) Using two of the small machine screws with flat washers, place these fasteners through the speaker mounting lugs and press them up through the existing holes in the foam supporting material. Secure the screws with flat washers and matching nuts from the back side of the inner door panel. The use of thread locking compound (Loctite) is a nice touch to prevent loosening due to vibration.
d) Re-install the sheet metal screws removed in Steps 5c, d, e and f. This will re-mount the speaker panel. Don’t forget to re-connect the speaker wire connector at the door panel.
7) Re-installation of the inner door lower and upper panels is literally a reverse of the removal procedure. No hidden tricks.
8) Perform Steps 3 through 6 for the other doors and the job is complete.
9) Remove Rear Footwell Mounted Speaker as follows:
This sequence is good for both 4” and 5.25” footwell mounted woofers.
a) Using a small flat screwdriver as a lever, carefully ease off the grill.
b) Using a #2 Phillips screwdriver, remove the four (4) sheet metal mounting screws.
c) Ease out the old speaker and release the electrical connector for the speaker wires.
d) Transfer the old speaker wires and electrical connector to the new speaker using solderless **** splices or by soldering the old leads to the new speaker terminals.
e) Re-connect the speaker wires to the harness by joining the electrical connector.
f) Mount the new speaker and re-attach the necessary sheet metal screws.
g) Press the speaker grill into place.
h) Repeat Steps 9a though 9g for the other footwell speaker.
Mar 10, 2010 | 1994 Jaguar XJ6
How do i change the side passenger mirror on a 2005 jetta (new body style)
I found I could get at the mirror assemby by unscrewing the philips screw on the front-inner side of the door, nearest the mirror, then "pop" the fasteners by pulling on the door cover and lifting it out of the window tray (might help if the window is down). The top corner of the door can then be pulled back about four inches, which is all you need (I propped it open for the remaining steps). Then unscrew the speaker cover (I think it's a T-20 size star head) and remove the foam backing. Now you can get to the bolt holding the mirror on, which is a 7/32 star/hex head (IIRC). Screw that off and disconnect the wire clip, then your new mirror should fit right on.
Sep 22, 2009 | 2005 Volkswagen Jetta
Speaker in back left passenger door keeps kicking in and out. I really don't want to replace the entire stero system.
You could just change that one speaker.
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you can unscrew the speaker and disconnect the wires and replace with a new one
Sep 16, 2009 | GMC Envoy XL Cars & Trucks
Fiesta 2001 driver's wing mirror
It's basically a case of taking the door panel off! (This is for driver and passenger sides). Firstly remove the screw holding on the black plastic cover where the mirror adjustment control is and remove the black plastic surround. There is also a circular piece of plastc behind the mirror adjuster, make sure you remove this (turn anticlockwise) otherwise you won't get the mirror out later on! Next remove the screw from the door bin, inside the recess in the arm rest part of the door panel and from behind the door handle surround. Carefully slide the door handle surround off (first towards the front of the car and then towards you). Once the surround is off carefully unclip the speaker wire from the back.
Once you've done all this you are ready to go - the door panel itself is held on by plastic poppers, there are around 2 either side and 3 at the bottom. Carefully unclip all of these so that the panel is loose. Then slide the panel up (there is a plastic fitting at the top of the panel which sits in the gap where the window is). The panel will now come away - be careful not to rip any of the thin foam like lining of the panel and also of the wires going to the speaker.
There are 2 more screws which hold the wing mirror on - unscrew both of these and the wing mirror will now come off. Make sure you keep the sponge padding as you will need this to help you hold the new mirror controls in place. Then its quite simply a case of fixing the mirror on with 2 screws and refitting everything in reverse of taking it off.
Oct 23, 2007 | LG KU990 Viewty
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
