Question about Onkyo TX-NR515
How to reset Onkyo TX-NR515 - Onkyo TX-NR515
2 Suggested Answers
SOURCE: Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Posted on May 12, 2008
Onkyo TX NR515 .. when in standby mode .. light is not coming on .. everything works fine .. i must have pressed something by mistake but cant work it out what ... on the display panel in standby mode...
If Zones are turned on or, if a mobile device connected to the Front Input is charging (MHL), the HYBRID STANDBY indicator won't light. See the TX NR515 owner's manual at http://filedepot.onkyousa.com/Files/own_manuals/TX-NR515_English.pdf for more info.
Feb 19, 2015 | Onkyo TX-NR515 AV Receiver
We have a tx-nr515 reciver and cant get sound from tv but everything else working fine?
Try plugging the TV into the AUX on the back of the receiver. If you get sound from the tv when you switch to AUX on the front of the receiver, then you know the tv is ok. You may also try connecting your CD player to the TV input on the back of the receiver, switch it to TV on the front of the receiver and if you have CD sound from the tv selector, then the receiver should be ok. Helps narrow down where the problem is. You may have to set the tv to enable its audio outputs in the TV's menu. It might not be putting out any sound until that setting is enabled.
Jul 27, 2014 | Onkyo TX-NR515 AV Receiver
Onkyo tx-ds 474
press and hold the video 1 button and then press the speaker A button - you should see 'clear' on the display. This will reset everything
Jul 14, 2014 | Onkyo TX-DS474 Receiver
Onkyo tx-nr515 no standby light,no power???
hi
check the primary circuit for faulty fuse or the circuit is damaged needs servicing.
good luck
Jul 08, 2014 | Onkyo Tx-sr507 A/V Receiver
How about a refund?
I had the same problem with my HTPC to ONKYO TX-NR515.
The issue was fixed by: Setup > Source Setup > Audio Selector > Audio Selector: HDMI > Fixed Mode OFF!!
Dec 24, 2013 | Onkyo CS-445 Compact Stereo System
Onkyo TX-NR515 will not stay on
pls. check speaker wires for any open cracks. try the speakers to another amplifier and if it works from there your onkyo must be in trouble. open the unit and check for any blown fuse, if found any replace it w/ the same value, do not replace fuses w/ higher value.
Jun 30, 2013 | Audio Players & Recorders
Onkyo reciver, cannot get radio to work
Check to make sure your fm antenna and am antenna cables aren't loose from the rear of the receiver
Jan 28, 2013 | Onkyo Tx-nr515 7.2-channel Network A/v...
Onkyo receiver flashing dts no sound
May 30, 2012 | Onkyo Audio Players & Recorders
Onkyo TX-NR515 Logo
123 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
