Question about Kenmore Ovens
Microwave wont heat on model 911.49485 / 911.49489
It started out when you open the microwave door, the turn table would start turnning, when you put your stuff in closed the door set the time and through the cooking cycle the turn table wouldn't turn, that was only sometimes, now the turntable doesn't turn and it will not cook
bigg t
  • 640 Answers
SOURCE: Turntable not turning and microwave not working
the switches are on the left or right side or both (there may be two).locate them and theres 2 wires on the switch.jump them out.if there bad replace them as it would be a hazard issue for radiation not to.
Posted on Aug 28, 2007
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
SOURCE: KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Posted on May 02, 2009
SOURCE: I have a Competence B1180, it cuts out after
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Posted on Sep 17, 2009
heatman101
  • 43501 Answers
SOURCE: OVEN TURNS ON BUT WONT HEAT UP.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
Microwave doesn't turn on, code "DOOR"
See if the door is crooked, low, or something is blocking it.
Dec 01, 2013 | KitchenAid KEMC378 Electric Double Oven
No heat and no rotate of the turn table. Everything else seems to be working as designed. This is the microwave
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
Jan 16, 2011 | GE JKP85 Electric Double Oven
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
Microwave has power...light lights and turn table turns but nothinng heats up and there is a smell of burnt electrical items
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 19, 2010 | KitchenAid KEMC378KSS Electric Double Oven
Hello we have bosch hbc 86 and every time i want to turn on the microwave it suddenly stops, even when im trying to defrost,it starts and then in 3 seconds it turns off, please do you have a solution for...
My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
Oct 15, 2010 | Bosch HBC 86Q650B Electric Single Oven
The microwave light is out. How do I change it??
I have a kenmore inbuilt and you take the front louver off and the light is under a flap inside. I also have a counter-top model and the only way to get to the lamp is to take the outside case off. On the model I have, there are 8 screws and one of them is tamper resistant, which means that you have to have the correct screwdriver bit to take the case off. Make sure that the unit is UNPLUGGED before you take the case off, and don't touch the electronic stuff. Also don't clean the insides. Get a long life bulb if you can so you don't have to do it again. And make sure the door switch is not bad before you start. Put something in the microwave, turn it on for a few seconds, then open the door a very short distance. The microwave should turn off, and if it doesn't, the door switch is bad.
Jun 30, 2010 | KitchenAid Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Hooked up a new control panel and now the oven only works when the door is open! what did i mess up? microwave works. light is on when door is closed, light turns off when door is open and then oven will...
door switch connections are reversed. will need a model number and make to give better info.
Please take the time to give this solution a fix ya rating and repost with needed info.
clarkco
Mar 19, 2009 | Whirlpool GMC275PD Electric Double Oven
GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Oct 25, 2008 | GE JKP85 Electric Double Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
Ovens Logo
69 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
