Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
How to remove high speed lock out screw on kawasaki
Adjust idle
!. New spark plug
2. New or CLEAN air filter
3. CLEAN and properly set carb.
4. Air screw should be about 2 turns out AFTER lightly seating.
5. Adjust idle speed to your liking, but not too high.
6. Refinement is made with 1/4 turns of the air screw.
Jul 08, 2014 | ATVs
Runs slow
In California the new blowers have sealed mixture adjustments and you need the have your carb. mixture adjusted be a qualified shop. If your carb. HAS mixture adj., turn the high speed mixture so it runs best at high speed, then turn another 1/8 turn counter clockwise to be a little rich. Then at idle adj. the other screw till it idles best.
Apr 21, 2014 | kawasaki Krb300a Backpack Leaf Blower
Rear wheels lock up at high speeds
Sounds like a bent axle.... or something in the rear differential. ...the heat generated by the bent axle will cause all the clearances to disappear!!!
Jan 01, 2014 | kawasaki 2008 Mule 3010 Trans 4x4
Idol to high
You have to adjust your idle screw on the side of the motor ...it should be by your carb. Turn your bike on and then turn that screw to the left until your motor calms down and has the correct idle speed.
Oct 28, 2013 | 2003 kawasaki KX 125
Idle adj screw vibrates out and the idle speed is high.
Hi Charles Gregory.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Make sure your spring that goes on the idle screw is in place.
You can also use some "locktite" thread locking compound on the threads of the needle if the spring is missing.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Oct 01, 2012 | Garden
How do i adj the valves on a 23hp kawasaki ?
You need to remove the rocker arm cover. Then most engines have a set screw and a locking nut that hold the valve rocker arm on. Loosen the locking nut and with a feeler gage make whatever adjustment you need (tighten or loosen) then holding the adjusting screw from turning, tighten the lock nut. It is not very hard to do and remember that they are all metric fasteners.
May 19, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
I have a 1995 kawasaki ts jet ski it runs but goes really slow will not hit high end. i just got this jet ski it looks like the carb and lower end of motor is new. i did find some water in carb and cleand...
If the carburetor was properly cleaned including the teeter-totter float needle then you may just have accidentally changed the setting screws. Try setting the the high end and low end adjustment screws the standard settings are: Low speed screw: 3/4 turns out (+ or - 1/4 turn for fine tuning) high speed screw: 1 1/4 turns out (+ or - 1/4 turn for fine tuning) If the previous owner rebuilt the whole machine but could not figure out why the boat would not rev out, the next thing to do is remove the water box and and split the halves. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch27834 If a mouse nest has been built in the exhaust system the extra back pressure could be the problem. If the exhaust coupler has broken rubber tubes, has come apart, or has not been put together correctly that might also be the cause of the problem. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch29444
Aug 08, 2011 | kawasaki Full Suspension Mountain Bike Men
2001 Kawasaki ZX-12R will not idle
Hi, Snowboard117 and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2001 ZX12r wont idle
Plz help just got 2000 zx 12r and im little confused
Kawasaki 2000 Ninja ZX 6R Service Manual Page 2
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
May 28, 2017 | 2001 kawasaki ZX-12R
Engine will not run at steady speed, govenor continually fluctuates , This engine is a Kawasaki FC420V-ES10 on a John Deere Riding Tractor Model LX176. I tried the mixture adjustment needle valve no help.
On top of carb you will see a jet that is slotted,remove with screw driver and use a very thin wire to clean out hole in jet.Some had a black metal clamp holding it in place,remove that one by removing phillips screw,black clamp then use small pliers to pull jet out of top side of carb.If this does not work remove carb bowl and jetting in bottom-center of carb and clean jetting holes with a small copper wire.The mixture screw is for low speed air/fuel mix,this engine does not have a high speed fuel screw.Fixed jet.
Dec 11, 2009 | Garden
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
24 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
