Question about Lochinvar Pool & Spa
How long is the thermocouple on model LSN041G
How do I replace a thermocouple?
Need the make and the model number of the heater.
Sep 29, 2016 | Water Heaters
How to change thermocouple on model 640YORT
I believe that is a Reliance 606, ehow has instructions on how to change the thermocouple.
http://www.ehow.com/how_6579030_change-reliance-606-thermocouple.html
Aug 24, 2014 | Water Heaters
Furnace thermocouple
older standard efficiency furnaces have a thermocouple. mid and high efficency models do not. they are electronic ignition with a hot surface igniter
Apr 16, 2014 | Goodman Heating & Cooling
Bernzomatic ph3200c thermocouple
Try ebay, amazon or you can use a generic one. Just ensure the thermocouple is secured properly in the area of the pilot flame.
Nov 13, 2013 | Pool & Spa
Maybe it sound strange but does anyone know where I can buy a thermocouple online?
Don't worry, it's not strange. I've also done some research into thermocouples. I came across a website that specializes in them;
Good Luck with your search
http://thermocouple-online.com/
Jan 28, 2013 | Plumbing
I changed the thermocoupler but problem remains the same: pilot goes out after about 10-15 minutes. I have Williams model 250912. Please help! How do I test if new thermocoupler is also bad, beside...
Remove the thermocouple and take a pencil eraser to the hole. Clean the corrosion out the hole. Reconnect the thermocouple tight. The tip of the flame must hit the tip of the new thermocouple.
If the flame is hitting the middle of the thermocouple that is called wash through (no good) The bimetal tip of the thermocouple is made of nickel and copper layered. When heated it produces millivolts. This holds the electromagnet in and that is your safety feature. Thank you Ralph Nader.
Jan 30, 2011 | Williams 2509612 Ceramic Mid-Size Heater
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Pilot lights but main burner dose not light when turned on
possibly a fowled thermocouple if the thermocouple doesn's sense the pilot flame then it will not send a signal to the gas valve telling it that its okay to open cause the pilot is lit.
Dec 28, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Natural gas patio heater
MAY I KNOW THE EXACT MODEL # OF YOUR UNIT.
Sep 27, 2008 | Heating & Cooling
Pool & Spa Logo
42 people viewed this question
Top Lochinvar Pool & Spa Experts
Paul Carew
rogerpaul3
Level 1 Expert
David Spradling
David Spradling
Are you a Lochinvar Pool and Spa Expert? Answer questions, earn points and help others
