FixYa.com
Tags:
IBM Internal 48x CD-ROM Drive
Puzzler: Memorex 48x plays songs for ten seconds...
By Bomber - usenet poster
My pal bought a new Memorex 48X Atapi cd-rom and I installed it for him
about 3 months ago. The thing worked fine for a while. Lately,
although it reads data and music CDs OK, it will only play music for a
few seconds before skipping to next song, and so on. Don't know how
this problem started, have never seen it before. How do I get it to act
normal?
Thanks for any help.
(email replies very welcome)
Laura Goodwin
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Grant
Grant - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Mark Lloyd
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
Sorry, wish it would have been the "grail" :)
Never thought that was much of a useful feature anyway, but damn if my car
stereo doesn't have the same feature.
Now, to the original problem...I looked at Memorex (not a lot of help there)
but they did list an audio skipping problem in relation to DMA, the
suggested fix being to uncheck DMA. Worth a shot, but it didn't seem to
match your problem 100%.
On the software track, what has been done to the system since the drive went
in? Did your friend try to upgrade drivers, add another CD drive (burner or
DVD) or tinker with the device settings? FWIW my CDROM (a Toshiba 40X)
shows up in Device Manager as not even needing drivers (on the Driver tab it
says "no drivers are required or have been loaded). But your case may
require some sort of driver for proper functioning. Didn't see much in the
way of help at # unfortunately.
One simple thing you could try (it would put you no worse off than you are
now) is to delete the device in Device Manager, reboot (Windows should
rediscover it) and if it isn't autodetected add it manually. Could just be
one of those mysterious glitches; doing this has fixed device problems for
me in the past, and if it doesn't fix it at least it shouldn't set you any
further back.
# had some info, not an exact match
though. To summarize, I'd try the following:
-use a different program (Winamp or Media Player, or something different
than what you are using) to handle CD audio...if the problem stops, the
original software is either gacked up or had a setting mis-set
-uncheck DMA, reboot and try a CD again.
-delete the device in Device Manager and reinstall it (either let Windows do
it or do it yourself)
-oh, yeah, check the physical connections (although if it works for other
things this probably isn't an issue...can't hurt though)
Good luck, don't smash it in frustration.
Robert Schumacher
remove IDONTTHINKSO to reply by e-mail
"I've always wondered why the needle is sterilized for execution by lethal
injection."
Solution #3
Not Rated (0)
Grant
Rating: 0%, 0 votes
Great. I did think to check into that after four hours of accomplishing
nothing 16 different ways, but although it's a worthy suggestion,
disabling the "feature" didn't solve the problem. I'd never used the
preview option and didn't even know it existed until today. :/ Found
it by poking around in a random pattern, and felt like I found the holy
grail when I disabled it. But it didn't help, even after a reboot,
etc. :::grumble:::
Right now if we want the CD-ROM to play an album I have to disable
auto-insert notification and just hit the play button on the drive.
Windows CD player app is useless. Another beautiful day in the
neighborhood. :/
Thanks for caring, though.
Laura Goodwin
Solution #4
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
What software is handling the CD music. Sounds like a feature in many
computer and normal CD players, a "preview" that plays 5-10 secs of each
track. Check the software (for example, the generic Windows CD Player has a
feature called Intro Play, on the Options menu...if checked it plays a small
part of the beginning of each track)
Robert Schumacher
injection."
Can you Help with these CD ROM Drives problems?
CD ROM Drives
cd rom for a206x
need cd rom for this model... Answer This...
CD ROM Drives
LG GDK 70
I am looking for LG GDK 70... Answer This...
CD ROM Drives
cdrom often lostii
i am having compaq presario... Answer This...
CD ROM Drives
cd drive
do you know thw dimensions for... Answer This...
CD ROM Drives
Message indicates the dvd drive...
I have a ccd-52X6D model star... Answer This...
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
