Question about Troy Bilt 5.5hp Self Propelled Mower
Belt replacement on troy bilt tb250 self propelled mower
How do you change it
  • 68 Answers
SOURCE: lawn mower
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Posted on Apr 26, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
SOURCE: Troy Bilt 33
If you didn't by the Troybilt belt, try that. I had the same problem with a Napa belt. Going into drive as soon as I grabbed the operator presence button, not coming out of gear etc. When I switched the the Troybilt belt, the problem went away.
Posted on Aug 16, 2009
RonInFla
  • 86 Answers
SOURCE: where is the oil plug located on a troy bilt mower?
Tilt it over so the oil cap is on the bottom...it'll rest on the handle and hang there...put a container under the oil fill pipe...something shallow like a glad sandwich container works perfect...get a paper towel, and reach under an unscrew the cap...all the oil runs out into the container...it'll fit !!
Wipe the dipstick off clean, and put it aside...take this time to look at your blade on the other side...it "should look" similar to wood chisel at the last 5 inches of the blade on both ends followed by a wing under it...BTW: their $12 bucks new...and worth it !!
Go back and look at the container and be sure the oil is finished draining...take the lid for the container and snap it on and move it out of the way (no body likes an oil spill)...wipe off the oil fill spout, and re-fill...takes about a half a quart, so don't over fill it !!!
your done...
Posted on Apr 17, 2010
  • 23 Answers
SOURCE: The self propel on my 22" troy-bilt mower works
put belt dressing on the belt
Posted on Aug 17, 2011
Troy bilt xp self propelled not switching gears
Check transmission fluid. Ensure belt is good or replace. Check belt tensioner if installed.
Apr 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How do i replace a drive belt on a troy bilt self propelled lawn
May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Need replacement belt guard for sovereign lawnmower
  1. Discount Troy Bilt Partsupstateoutdoorpowerequipment.com Save Up To 35% on Troy-BIlt Parts. Save Up To 35% on Troy-BIlt Parts.
  2. Troy-Bilt Partswww.partstree.com/troy_bilt_parts Need Troy-Bilt Parts? Look Up Parts and Diagrams for All Models.
  3. Troy Bilt PartsSearsPartsDirect.com
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!!
http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
174 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
