Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer was squeeking now not spinning
Dryer was making a loud squeeking noise and now when it's turned on I hear it on but the container is not turning.
  • 221 Answers
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Posted on Mar 11, 2009
When do i know when is over load
The WASHER will Spin Off Balance.,making loud noises.,and Shake alot.,you also may hear squeek noises from THE overloading of clothes..,in THE Belts too..around inside THE Pully."
Feb 24, 2013 | Frigidaire Washing Machines
My kenmore electronic dryer makes a squeeking noise when it spins
Open it up and and put some grease on the fan. The other cause is - untied bolts.
Jan 21, 2013 | managemylife.com
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
My maytag legacy dryer SDE305DAYW has a very loud squeeking noise when I start the dryer. After a minute or 2 it stops making the noise. Is this the belt?
While I would suspect the belt also, it could also be the drum bearing since they both could have the same symptoms. Suggest you try to turn the drum by hand and see if you can hear it then.
Aug 13, 2011 | Dryers
The dryer is making a squeeking noise as it turns then turns into a big rumble like it might be off track. And it's loud! Belt is tight. Help!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 10, 2011 | Maytag Dryers
Squeeks and creeks from the front right wheel on my honda civic
you could have 2 problems. steering leak and poss a bearing. jack up the car and spin the right front wheel, makes noise there is a problem. if the noise only happens when you turn, with tire off turn the wheel and watch.
Mar 06, 2010 | 1997 Honda Civic
Car makes a squeeking noise when driving then it killed on me today when the squeeking was very loud.
check for a siezed pully under the hood remove the belt and check to see all pullys spin free with no noise also check the AC clutch make sure it free spins.
Dec 02, 2009 | 2002 Ford Mustang
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
189 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
