Question about Sewing Machines
How to use my brother model 847 sewing machine
How to get started
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 6 Answers
SOURCE: manuals for old brother sewing machings
You can get a manual at www.ifixmachines.com or you could try www.brother.com. Best bet is the general manual order form, I'd pay with paypal.com and they'll get you the manual or refund your money.
Good luck, that seems to be a older model
Posted on Jan 16, 2009
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
Posted on Aug 03, 2009
  • 980 Answers
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Posted on Nov 04, 2009
Jimsta01
  • 405 Answers
SOURCE: How to thread a Brother cs-100 sewing machine
Please follow the link below, for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
Posted on Mar 30, 2010
Once start sewing back stitch will not stop
sounds like the start and stop button is starting to malfunction, probably needs to be checked
Mar 13, 2016 | Sewing Machines
I ordered a class and paid for it but when I try to listen to it the film stops and will not start again
Ruth, contact the company that you purchased the class from and tell them that it is defective and you want your money back.
Best regards,
Bill
Oct 25, 2014 | Sewing Machines
How do I start my machine after I'm done positioning it.
Not sure what model sewing machine you have. Viking machines are usually started using the foot control (depressing the foot control will start the machine). Some models have a Start/Stop button that will start the machine sewing.
Hope this helps. Good luck.
Oct 21, 2014 | Husqvarna Sewing Machines
Start/stop button
In order to use the start/stop button the foot pedal must be unplugged.
Jun 15, 2013 | Simplicity Quilter's Classic SW240...
How to start the snowblower yard machine when you've tried everything to start it up correctly and it doesn't start?
How did you store it? The gas should be drained out of the carburator and tank prior to storing. If you don't do that it starts varnishing the jets closed in the carburator. So to start it, try draining all the old gas out. Take the spark plug out and put the wire back on and lay it on top of the block. Crank the engine over turn switch on if it has one, does it have spark? If it does good. If not try a new plug, if it still does not have spark you will have to pull the flywheel to see what is wrong with the points or pickup. Once you have spark established, put new fuel in tank. Spray a little WD40 into spark plug hole. Put spark plug back in and go through normal starting procedures. Good luck.
Jan 06, 2012 | Sewing Machines
It keep coming unthreaded at the need when i start sewing
You must hold the top thread at the start of every row of stitching, if you dont then the tension will pull the thread backwards.
May 16, 2010 | Sewing Machines
"START" ON MACHINE FUTURA CE-100
The start switch is the Led indicator buton. You will see it on page 12 of your manual. It is on the right of the needle bottom button.
Good Luck
Please Rate FixYa!
Dec 19, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Centering the starting point
Unfortunately you can't. It is imposible to move the neddle because of the machine limitation. It will only move to the starting point according to your design.
Jun 07, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
80 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
