Question about Garden
Honda HR215 starter rope
The starter rope pulls out and returns OK - but the flywheel does not seem to engage to turn the engine over.
  • borgerr2000 Mar 14, 2009
    The problem was that the cogs in the rope pull mechanism were damaged. They were fixed and the problem was resolved.
  • Anonymous Mar 31, 2014
    When I pull the rope on my Honda HR215, it fires up, revs up for about 5 seconds and dies. It takes about 30 seconds before it will start again. I have cleaned the main carburetor jet and the needle valve. I don't have any idea how to make external adjustments.
  • 221 Answers
Try checking the spark plug if it sat for a long period of time it may be faulty, or the fuel might have built up condensation in it.
Posted on Mar 11, 2009
Have2002 honda accord starters new but wont turn flywheel flywheel teeth looks ok but wont start?
a mechanic knows the difference between cranking/turning over and starting
you say that the flywheel is not turning so obviously it will not start
now you have to tell us if the starter pinion is engaging in the flywheel teeth but the starter is not cranking the engine --indicates that the engine is seized up
now it it is an automatic , there is a possibility that the flex plate ( automatics do not have flywheels )) is broken and the teeth are no longer in a position to mesh with the pinion gear
Aug 20, 2017 | Honda Cars & Trucks
Starter rope is locked. Cannot turn by pulling cord
Hi Bob:
Sounds like the engine is seized.
Try removing enough bits so you can access the flywheel and see if you can turn it. Make sure ignition is OFF.
If the flywheel does not turn it will be time for a learning experience, a trip to the maintenance shop, or a replacement.
Sep 16, 2015 | Coleman Powermate Powermate 5000W...
I have a 3hp briggs & stratton//the pull rope pulls freely//it does not engage the engine and turn the engine over
You probably need to replace the starter recoil. This is not a very expensive fix. Just be aware that this problem is usually caused by having to pull the starter rope excessively because of some other starting problem. Once you replace the recoil, keep your engine running properly.
Sep 07, 2014 | Garden
Why is the rope starter not engaging the motor how do i fix it or do i need to return it
Try pulling the rope slowly until the starter engages the flywheel (you should feel when it engages) then give a good pull to start the engine. Don't give the rope a quick hard pull in one motion. You will probably need to do this three or four times before the engine starts. Of course push the primer button the number of times called for in your engine instructions before trying to start the engine. If you still don't think the starter is engaging the flywheel if would take it back where you bought it if it's new.
Jun 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Pull cord won't engage
remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
May 04, 2014 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Briggs and Stratton 5hp starter shaft doesn't engage
use the free sign and encourage people to take it
Apr 12, 2017 | Atlas Translator Garden
1994 Camry 4 Cylinder-Starter spins fine but does not seem to engage the flywheel. I have a new starter and battery. Im not ready to get into the flywheel. What else can I test to see why its not engaging...
Well, the easiest solution is to pull the starter and bench test it. Likely areas for your issue is the starter drive, and flywheel teeth. You need to inspect the teeth of the flywheel.
one quick test would be to manually turn the engine to another location and fresh teeth on the flywheel, and try starting again. Engines tend to stop at some spots, and that can cause unusual wear on teeth in one small location.
Sometimes rebuilt starter do not get all new parts, but only what is failing, so it is possible to get a malfunctioning starter drive. Starter drive failure usually turns the engine over briefly, then the starter disengauges....
Feb 05, 2011 | 1994 Toyota Camry
When I pull the manual starter cord, it doesn't make the crankshaft turn. What's wrong ?
Check these:
Can you hear the "dogs" engaging in the flywheel when you initially pull on the cord?
If you remove the recoil assembly from the engine then will the rope pull out?
Is something preventing the blade from spinning underneath?
Can you turn the engine over manually by turning the flywheel?
If you remove the spark plug will it turn over?
One of these should help determine the problem. Good luck!
Oct 22, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Where is the starter located on 1985 Honda Civic?
The starter is located on the firewall side of the engine block, adjacent to the flywheel or torque converter housing. Early models, use a direct drive type starter, while the later models use a gear reduction starter. Otherwise, the two units are similar in operation and service. Both starters are 4-pole, series wound, DC units to which an outboard solenoid is mounted. When the ignition switch is turned to the start position, the solenoid armature is drawn in, engaging the starter pinion with the flywheel. When the starter pinion and flywheel are fully engaged, the solenoid armature closes the main contacts for the starter, causing the starter to crank the engine. When the engine starts, the increased speed of the flywheel causes the gear to overrun the starter clutch and rotor. The gear continues in full mesh until the ignition is switched from the start to the on position, interrupting the starter current. The shift lever spring then returns the gear to its neutral position.
Begin the starter removal by first disconnecting the wires leading to it
Hope helps (remember rated this).
Jul 14, 2010 | 1985 Honda Civic
Garden Logo
575 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
