Question about Craftsman Garden
How to replace flex shaft model 316292710 craftsman tiller
A rock jammed between tine and casing; the tines stopped but the engine continued to run; suspect flex shaft broke. I am looking for replacement instructions.
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
  • 3074 Answers
SOURCE: engine runs fine ..after about 2 min, of running
check the belts
Posted on Apr 17, 2011
  • 352 Answers
SOURCE: my craftsman mini tiller 316292710
Hello.
There is a product called "thread Lock" that can be purchased from most hardware or automotive supplies shops. this product is like a glue that can be put on the bolts before tightening them up and it will help keep them in place. Make sure the bolts are clean from dirt or grease also before using it.
Vibration from the motor the most likely cause of the bolts coming loose all the time, this product will stop this.
I hope this helps, Regards GM
Posted on Jun 03, 2011
hunter19_46m
  • 7482 Answers
SOURCE: homelite htc 12 tiller.. motor
Hi bh1149...
You have bad gears on the inside of the tiller gear box...
I had this same problem with mine.
You will have to take the gearbox apart in order to know what parts are bad.
Be sure to check the lube more often when you install the new gears/parts.
Go to the following website and order your parts.
Please take time to rate me
http://www.ereplacementparts.com/homelite-parts-c-18807.html
Posted on Sep 09, 2011
Testimonial: "very helpful "
Tiller runs great just having a problem with the tines turning plowed my garden last week and for some reason the tines quit turning like its locked or something please help me
Two possibilities. Something has jammed the tines.
Pull the spark plug wire off and tuck it away someplace so as not to touch the plug.
Tip the tiller up and examine the tines for obstacle such as a rock. If there is nothing jammed try to turn the tines by hand. If the they turn freely you most likely broke a shear pin that secures the tines to the axle.Clean the axle and tines and examine very closely for the pin.
If sheared ( broken) you will need to drive the broken piece out and replace the pin.
There may also be a problem in the transmission case. You would need to remove the tines and case to open it
Apr 01, 2016 | Garden
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
I have craftsmen 5HP rear tine tiller,while tilling picked up a rock which jammed the tines and stalled the motor. when i restarted it had loud grinding noise and then locked up stopping me from being able...
If the tiller tines where jammed, the tranny and motor where still trying to turn and there could be a couple different parts broken. The tranny main shaft make have busted, the tranny gears could have jammed. If the motor does start, than that is a good sign. If not than the connecting rod or crank may have snapped.
I am guessing you will probably have to dismantle the transmission and see if there are any broken gears or shaft.
May 09, 2009 | Craftsman Garden
Craftsman model 917293310 rear tine tiller won't come out of '' F
you need to soak the shaft running through the case with a good penetrating oil probably. they rust up and seize
Apr 27, 2009 | Garden
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
50 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
