Question about Sharp FO DC600 Plain Paper Laser Fax
Sharp Fax - Change outgoing name/number - HELP!
We purchased a used Sharp Fax FO-DC600. I need to change the company name and phone number - I've spent WAY to much time scrolling through the menu mode....HELP!
~Claudia :)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
HOW CAN I CHANGE MY FAX NUMBER IN A SHARP FO-4400? ITS STILL SHOWING MY OLD ONE
You can get the manual at http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/FaxMachines/Manuals/Archive/fax_man_FO_4400.pdf
Page 24-27 cover the setup of the phone number, date and time.
Press MENU and then 3 Press 0 and then 3 Enter Fax number Press START
Sep 15, 2011 | Sharp FO-4400 Fax
How do I change the company header on this fax machine?
with function key go to entry mode and own number set .change name and number
May 20, 2010 | Sharp FO 5700 Plain Paper Laser Fax
Sharp Dc-600 Fax turns On And off
As weird as this sounds, it could be a bad toner cartridge.
Jan 25, 2010 | Sharp FO DC600 Plain Paper Laser Fax
Is there a way to change the Baud rate on a Sharp FO-DC500? My phone company is telling me it needs to be @ 3200-3300?
Your phone company is lying to you.
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Nov 10, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Need to change the outgoing name and address on a Canon fax G3 L2
To change outgoing name and address, use the following procedure:
1 Press Function.
2 Press Data Registration.
3 Press OK twice
4 Use UP Down arrows to select Unit Telephone #
5 Press OK
6 Use the numeric buttons to enter your fax/telephone number (max. 20 digits,including spaces).
• To enter a space, press Function
then Space. Spaces are optional
but make the number easier to
read.
• To enter a plus sign (+) before the
number, press #.
• If you make a mistake, press C and
re-enter the number.
7Press OK twice.
8 Use the numeric buttons to enter your name or company name (max. 24 characters, including spaces).
9 Press OK.
10 Press Stop to return to standby mode.
Below is a link to your L=220 User Guide:
Canon L220 User Guide
I hope you find this answered your question. Best of luck to you!
Greg
Nov 06, 2009 | Canon L220 Plain Paper Laser Fax
I need to change the company's name on the printout page when someone receives it.
The 6600 opeations are very similar to the 6700. Go to the Sharp site at
http://www.sharpusa.com/products/TypeManuals/0,1083,23,00.html
download the FO-6700 manual, follow the instructions for setting the sender name and phone number beginning on page 29 of the manual.
Please make sure to rate this solution.
May 15, 2009 | Sharp FO 6600 Plain Paper Laser Fax
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Changing a name
This model number appears to be a copier. Are you sure you have the right model?
http://safemanuals.com/zearch_634.php
Aug 25, 2008 | Sharp AR-F152 Fax
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
Problem
Usually, you can just leave the thing unplugged- from the power supply- for a while and clear its memory. There may also be a reset button on the machine, look for it near where the ports/connectors are, and hold it down- most devices will flash a light or beep if the reset is done properly.
May 23, 2007 | Sharp FO DC600 Plain Paper Laser Fax
Sharp FO DC600 Plain Paper Laser Fax Logo
237 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
