Question about Fellowes Powershred C-220 Strip-Cut Shredder
Fellowes Shredder C-220 (Auto-on sensor is blind = no shut-off)
Problem: Auto-start sensor is ''blind.'' If fed paper in "Auto-on" mode, it runs continuously until I shine a bright light down the paper entry and then it stops. How do we correct this? [Already went to ''trouble shooting'' web site. Already do the oil maintenance on the machine.]
    An expert whose answer gotĀ voted for 100 times.
  • 121 Answers
OK lets try.
You obviously have a photo sensor that detects the paper and it is dirty.
The sensor will be in the proximity of wher you are shining the light.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
Hope this helps
Posted on Mar 15, 2009
Motor problem
It sounds as if the SafeSense is improperly shutting of the forward sensor. Call Fellowes and see if they can help.
If you do not have the manual use the link below:
Fellowes Shredder Manuals
Aug 18, 2014 | Fellowes 75cs Cross Cut Shredder -...
Ps-60 repairs
I own a Fellowes PS 60 shredder.
It could be that the sensor has trash or it is sensing something. Check it carefully if you see trash/debris cleanit with a Q-Tip or air blower - !DO NOT USE ANY WATER OR SOLVENT! -
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
Fellowes Shredder PS60
Mar 27, 2013 | Fellowes Powershred PS-60 Shredder
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
May 25, 2011 | Fellowes Office Equipment & Supplies
The shredder will not automatically shut off. After you have finished feeding the documents to be shreeded the machine contunues to run and you must manuall shut it off.
depending on what you have available, either a damp paper towel or alcohol wipe, or compressed air will work to clean the sensor eye located top at the center of the paper feed opening, you should see a little dot wipe, or spray these out well, then turn the machine off and back on again.
built up dust from the paper causes the sensor to keep registering that there is paper coming in hence it won't stop on its own.
Apr 05, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
Fellows C-320/C-320C shredder runs continuously. It will not stop. I have cleaned the paper sensors, and nothing seemed to change. When the machine is on and running, I(Auto On), O(Off), and R(Reverse)...
sounds as if you will need to have the auto feed sensor replaced. if they fail it will just run, thinking it sees paper. your machine is under warranty for three years from the date of purchase. call fellowes and see if they have repair depot in your area. 1-800-955-0959
Mar 31, 2011 | Fellowes C-320 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website:
Dec 15, 2010 | Fellowes Office Equipment & Supplies
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
PowerShred C-220 will not shred automatically
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
Hope this helps
Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
Shredder does not turn off
You need to clean the paper feed sensors. You can call Fellowes customer service at 1-800-945-4545
Feb 11, 2008 | Fellowes Powershred P-55C Light-Duty...
Motor not shutting off in Fellowes Powerhouse C-14 shredder
this is an issue with your paperfeed sensor. You need to call Fellowes at 1-800-945-4545.
Dec 18, 2007 | Office Equipment & Supplies
Fellowes Powershred C-220 Strip-Cut Shredder Logo
727 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
