Question about Uniden Cordless Phone
Cannot get dial tone for model 28213 ge cordless phone
I do not have the instruction booklet, just need a little help
It will continue to de register itself - I have one and have to do this continually. (At least every 2 days.) Go into menu - and to initial - then to register  and re register it.... it does get old, but at least it will begin to work after this. Good luck. If I still had the box I would return it in a heartbeat!
Posted on Mar 12, 2009
Need the instruction booklet for the model # DCT6485-3HS 328E 1203 - We can not get a dial tone
user guides provide details for telephones least in functioning order. A dial tone is attained from a teleconnection agency. For example, new telephones least that are broken would require that a telephone networking company be contacted about establsihing live interactivity. refer from the local networking agencies also attainable from phone books as reference places.
Jul 20, 2011 | Uniden Cordless Phone
No dial tone or just static or 2 beebs
I HAVE THE EXACT SAME PROBLEM. I'M ALSO LOOKING FOR A SOLUTION.
WHEN MINE DOES THAT I UNPLUG THE ADAPTER FROM THE WALL FOR A COUPLE SECONDS THEN PLUG IT IN . IT'S VERY ANNOYING. IF I FIND THE SOLUTION, I'LL LET YOU KNOW. IF YOU GET A SOLUTION, MAYBE
YOU CAN LET ME KNOW.
toom45@verizon.net
Jun 09, 2009 | Uniden Cordless Phone
GE Model 28213 Series DECT 6.0
Yay I just found someone give this as the reason why and how to fix it! Hope it helps, i'm going to try it and see what happens. Its better than unplugging it every time I want to use it!
http://en.allexperts.com/q/Telephony-Clecs-Long-2450/Cordless-phone-interference.htm?zIr=5
Aug 18, 2008 | Uniden Cordless Phone
Cordless phone Model 28213 DECT 6.0 multi
model 28213 GE..when I call out the people can't hear me..checked the mute and it's off
Aug 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 5.8 ghz cordless phone
the menu will take you to registering the hand sets to the base unit
by deleting incoming calls you have disconnected from the line
follow the instructions in the user manual to get reconnected
if you do not have the user manual , go google and type in --user manual for ge ( model ) cordless phone --and down load the pdf version
May 25, 2017 | GE 27957GE1 Phone
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
Dec 06, 2007 | GEH5450 Cordless Phone
2003 Phone- no dial tone GE CORDLESS 900MHz
I am having the same problem with general electric model 27939ge3-a . I am very displeased with the GE website(s) as it is difficult to manuveur around to find any user manuals.
Next time I purchase a phone, I will check the manufacturer's help support first.
As to a solution. I may try purchasing a new battery. Perhaps it is a power issue
Oct 30, 2007 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Tone volume on tough tone dialing pad
Instr man is here:
http://www.home-electronics.net/ge/pc/IB/27957GE1_IB.pdf
Jun 25, 2007 | GE 27957GE1 Phone
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
Uniden Cordless Phone Logo
126 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
