Question about ViewSonic VA912BWB 19" LCD monitor
Replacing backlight, but kind of lost (Viewsonic VA912b)
At the part where we removed the actual silver monitor casing from the black plastic casing, but we still cant find the actual slot for the back light.
Any sort of instructions would be a huge help. So far we have been winging it up until now.
a picture...
http://ecx.images-amazon.com/images/I/41D5H8RYQAL._SL500_AA280_.jpg
First is this monitor still under warranty? If it is contact the manufacturer. If not the first thing to do is to get the manual. If you can't find the one that came with your monitor Google the Model# and brand name. Choose "downloads" there you should find manuals and info: if not use the support option and ask them for the needed diagrams and info that you need.
Posted on Mar 11, 2009
How do you remove the plastic back from prolite e2200ws I have removed the 5 screws but moulding still does not wish to move.d
These are held together with plastic tabs. You will need to start in one corner and gently pry the case apart. GENTLY is the key. Most often, the front piece has the tab that fits into a little slot on the back of the case, so when you pry it off, you will actually be using a motion that bends the front of the bezel a little toward the center of the screen and pushes the bottom outward. Work your way around the screen.
Nov 09, 2011 | iiyama PROLITE E2200WS WIDESCREEN LCD 22"...
HOW DO I install new memory in acer aspire L320
First step would be to lookup your system specs either in your manual or at the Acer website. See what RAM is compatible with your system. Once this is done purchase what you need. Open the case and you should see the RAM modules & slots. If you are replacing RAM you will need to remove the old first. If you are adding to empty slots just line it up properly and seat it in the open slots. Close the case and reboot. System should automatically recognize the new specs. Make sure you disconnect power and properly ground yourself before touching anything inside your case. Hope this helps.
Oct 16, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
How do I get the case open on my Dell Ultra Sharp 1703FPs?
kenm951, You may want to see some vids on YOUTUBE that show disassembly of LCD monitors. Some of the longer ones (8 to 12min) are ok, but audio leaves something to be desired. The big question to you is why would you even want to open up your monitor?????? Bye for now. I'm louie12fix on fixya
May 06, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
How to open a ACER AL1713 monitor
Hi - there are more hidden screws so you need to undo those:
  1. Where the stand joins on the back, there are two plastic bits either side of the pivot. They don't look as if they come off but if you squeeze them (squeeze top and bottom) then they unclip.
  2. Remove the 4 metal screws you have just revealed (2 each side)
  3. Remove the 4 larger metal screws holding the stand to the monitor
  4. Remove 1 metal screw that you have just revealed which was hidden by the metal plate on the stand holder.
  5. Use a straight-bladed screwdriver to create a gap at the bottom of the monitor between the silver front / black back of the case.
  6. Open this up all around, and remove the silver front - undo the multi-cable connector which connects to the operating buttons and put the silver part to one side
  7. Lever out the monitor chassis.
  8. Put the LCD face down on a table but make sure there is nothing underneath it (I have two black blobs where mine sat on a bump in the table!)
  9. Then open up the cage with the electronics in it, by undoing 2 screws and sliding the cage off.
  10. Remove the four screws holding on the power board (the big one with a mains connector, disconnect any connectors, and then remove the board.
If your monitor is not working (even if the power light is dead), check for swollen electrolytic capacitors (tall things with an x at the top, made of metal with plastic around them). If you have swollen ones, that's probably why the monitor doesn't work. Replace them (make sure the + and - sides are in the correct places when you replace) and hopefully your monitor should work.
If it still doesn't work, look for any heat damage and poor soldering.
Apr 10, 2009 | Acer AL1713 17" LCD Monitor
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
Lg monitor l194wt
It's not glued!!!! It's clipped together...and DON'T take out the screws first...
First, turn the monitor upside down and look at its thin edge. See where the grey bezel meets the black case? That's your clip point, all the way around the monitor. The reason you want to start here? This monitor is VERY tight, and there's a good chance you will mar the plastic, so it might as well be in the least visible place.
Next, fit a plastic trim removal tool (you have one of those, right? Right!? :) ) in between the black and grey plastic, halfway along the length of the monitor. If you have difficulty getting it in, run it back and forth until you find a loose point, but you'll eventually have to come back to the tight spot.
Here, there's a little bit of finesse required...you have to pry the grey part (which I will start calling the "bezel") gently upward, not away from the black plastic (which I will call the "case"), perpendicular to it. This will pull a clip up out of its slot. When you feel the clip release, now you can move it slightly away from the case, but don't remove the trim tool. Keep unclipping the rest of that side.
Once you've gotten the hang of it, do the next side. This bezel is particularly tight, so don't start at the edge...you will definitely damage it. Once you've gotten two sides loose, the whole job becomes easier, but still stay patient and careful, because there's a lot of potential for damage.
Now that you've gotten the entire bezel off (and the hard part is over with), hold the LCD in place as you turn the assembly face down onto a soft cloth, like a blanket or comforter. Now you can remove the four screws from the back.
Lift the case off and remove the two screws holding the switch assembly. This will lift off easily.
Lastly, partially remove the silver tape holding the electronics case on the back, carefully remove the connectors (remembering their positions, of course), and you're ready to play electronic doctor. I'm posting this with my newly repaired L194WT. :)
Jun 14, 2008 | Gateway FPD2275W LCD Monitor
Sim card installastion
1) Remove the back cover
2) Remove the battery
3) Look to the bottom of the battery compartment and find SIM card slot. The slot will be located between the silver metal and black plastic edge. Slide SIM card into this slot with the notch on the SIM to your bottom left. Slide in until it is flush with the edge of the black plastic.
4) Install battery
Replace rear cover.
May 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Dec 28, 2006 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
188 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
