Question about Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Four colors in a switch L,1,2, 3 which one goes where?
How to install new ceiling fan 3 speed switch with the 5 wires on the condenser?
Sales person should have written down what color wire goes into which slot on the switch. If you have two wires on the same end, and the same color, one of these goes into the #1. Black usually goes into the L slot. But, none of this matters if you don't have the correct switch. Just because it looks the same on the outside doesn't mean it's the same on the inside.
Oct 05, 2015 | Dryers
Have have a westing house switch no.77286 with a l123 and colored black yellow blue and white color wire which color goes to those no.
The black usually goes to the L. The others you'll have to play with, If it's the correct switch. You should mark down what color wire goes into which slot BEFORE you take them out. DO NOT CUT WIRES!
fanman9952@aol.com
Sep 18, 2014 | Dryers
Where can i purchase a 4 wire switch
You can't just get a four wire switch & think it's going to work on your fan. That's just a low-end store brand fan so I would need to know how many wires on your capacitor & what slots & color of wire goes into pull chain switch. DO NOT CUT WIRES!
Sep 02, 2014 | Hampton Bay Dryers
Do not know color coding for ceiling fan speed control witch WU Pin 198635
How many wires on capisitor? Black usually goes to L. Should write this down before removing switch. You can't buy any swich off a rack and expect it to work even if it looks the same on the outside.
www.fanfairceilingfans.com
Mar 20, 2013 | Dryers
I have a four way switch that is not working when i hook it up what woul seem to be the problem with it
If you have a four way, it should mean you have two other three ways. lf so, wires are probably crossed. At each three way, you should have one wire on the dark screw. At one end, this wire will be the hot. At the other end, this wire goes to the light. At each three way, you still have two screws. these are the same color screw, and the wires on these are called travelers. They should only run switch to switch. When you have a four way, it is just in the middle of this run. so, two wires coming from one 3 way, and two wires coming from the other 3 way. Look on the box for the new four way, or see if it shows you which screws are in and out. Then hook up accordingly
Feb 18, 2011 | Leviton Decora Gray Rocker 4-Way AC Quiet...
3 way switch diagrams
Three way switch diagram: Three-way switch has 3 screws
Before replacing old 3-way switch, mark the wire connected to dark-colored screw
Connect that wire to dark-colored screw on new switch.
If you are confused which wire goes to dark-colored screw
Mark the 2 black wires and the red wire.
You are not going to do anything with the white wire.
Connect blacks and red to any screw, turn on power, and try BOTH switches
Keep trying until correct combination is discovered
Both switches must work in all possible up-down positions before wiring is correct
Incorrect wiring will not blow circuit breaker, the circuit just doesn't work until wires are right.
Four way switch is added to 3-way circuit
Oct 09, 2010 | Garden
I have a 2000 dodge dakota and i bought a universal h20 sensor and i need to know what the wireing digram for the sensor is the colors on the truck are orange/green and yellow/white and black/blue and...
Ok, the truck - org/grn goes to one of the sensor heater wires (wht).
The truck - blk goes to the other sensor heater (wht).
The truck - blk/blu goes to the sensor ground (grey)
The truck - yllw/wht goes to the sensor signal wire (blk)
Apr 07, 2009 | 2000 Dodge Dakota Quad Cab
Fuel injector problem
red and white with yellow go to #1 and #3.
blue and white go to #2 and #4
Oct 25, 2008 | 1987 Toyota 4Runner
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
Trying to rewire cartridge
Red - Right Channel +
Green - Right Channel -
White - Left Channel +
Blue - Left Channel -
Regards
John w
Jan 30, 2008 | Audio Players & Recorders
Heritage (5BFW52NK4KG) 52'' Ceiling Fan Logo
53 people viewed this question
Top Heritage Dryers Experts
roeb
Ottoniel
Mike
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
