Question about Yamaha RAV320 Remote Control WG646100
How do i set up my rav320 remote control to operate my toshiba tv
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
My rca remote turns the toshiba tv on but it dont change channels
U are using an RCA remote with Toshiba tv. You are lucky that it even turns the set on. You have different remote frequencies involved and need to use the Tosiba remote or a universal remote that will operate volume, channels and power.
Mar 17, 2015 | RCA Televison & Video
How do I program toshiba vc-sb1 to operate a samsung pn43e450a1f tv?
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
May 20, 2014 | Toshiba WC-SB1 Remote Control 72799183
I lost the instructions for operating my 3300 one for all remote control. Please help me program my Toshiba tv so I'll be able to operate my tv set.
Turn on your Toshiba TV. On your remote, press the TV key. Press and hold the SET key depressed until the red LED blinks twice, then release it. Press the 0, 1, 5, and 4 keys. Point your remote at the TV and press the POWER key. Your TV should turn off. If not, repeat the programming routine pressing the 0156, 0060, or 1256 keys
Oct 03, 2013 | One For All URC-3300 Remote Control
Need toshiba tv set up code for one for all big easy remote controle
If you are in need of remote control codes for a Toshiba TV, I recommend contacting Toshiba directly at 800-631-3811 for further assistance.
Nov 26, 2011 | One For All URC-4330 Remote Control
I have lost the Yamaha rx-v559 AV receiver remote control, could you please advise where i can get one from?
http://cgi.ebay.com/YAMAHA-RAV320-REMOTE-CONTROL-PART-WG646100-/170586109145?pt=LH_DefaultDomain_0&hash=item27b7b974d9
Here's a link to one on EBAY for 22.00 Hope this helps.
Jan 11, 2011 | Audio Players & Recorders
Toshiba CF32H50-no control from remote
Could be the remote does not operate on the correct frequency, but also may be the IR reciever sensor inside the TV, best bet is to bring your remote to a pawn shop and try it on a set there (they sell older model sets look till you find one like yours). once you determine the remote is OK, check the IR sensor for bad solder connection or replace it by soldering a new one in. Also some Toshibas develop micro CPU issue (the computer IC), another thing you can try is cleaning the main board control area with electrical cleaner residue can load down the control circuits but then the buttons would also malfunction.
Aug 01, 2009 | Toshiba CF32H50 TV
Remote stopped.
I was able to find the MSN TV Set Up Guide Manual online. Within it was the list of codes for various brands of TVs. One of those for Toshiba TV was in bold print. I used the instructions for entering the code and used that bold printed code. The remote worked both the Toshiba TV and the MSN TV2 unit after that code was entered. Apparently the remote had lost the original code somehow.
Apr 09, 2009 | RCA MSN TV 2 Digital Media Streamer...
I have a Toshiba tv/dvd combo. My remote will not operate the dvd
You might have to re-program the remote, here is the link for the owner's manual which tells you how.
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
Feb 19, 2009 | Toshiba CT-90157 Remote Control
Toshiba 36AF43 will not operate via remote control (Yes, the batteries are fresh!)
try unplugging the tv and allow the tv to remain unplugged for a least 5 minutes. This will force a reset on the tv which should resolve your remote issues.
Dec 17, 2007 | Toshiba 36AF43 36" TV
Yamaha RAV320 Remote Control WG646100 Logo
43 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
