Question about Electrical Supplies
Powerstorm 6500 engine working but no power
I was hoover away then the hoover stopped working everythings fine checked fuse is fine checked for loose wires all ok trip switch ok volt meter is on 0
  • 249 Answers
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Posted on Feb 23, 2008
reddevil6
  • 1673 Answers
SOURCE: Central vac (Hoover) always on!
There should be a manual/auto switch. If it is in the manual mode, then it will run all the time. Other then that you probably have a stuck relay. But this will have a years warranty on it, so you should be able to have it serviced under warranty.
Posted on Mar 06, 2008
  • 58 Answers
SOURCE: Reverse lights not working.
Most likely. It sits on the front of the gearbox and has 2 wires going into it. Remove the plug and bridge the wires with a small piece of insulated wire. Turn ignition on. If lights are on change the switch
Cheers John
Posted on Dec 12, 2008
wyatt1582
  • 453 Answers
SOURCE: 4 wd will not engage ,indicator lights on dash do not light
If its not engaging into 4 WD the vaccum actulator is more than likely stuck. The actulator is located on the front of the axle next to the the front gear hub it will have a plastic cover over it. Unbolt the two 10mm bolts that hold the cover on and spray down with WD-40, also pull back the rubber cover thats on the actulator staff and spray it. You might have to hit the staff a few times to get it to move just make sure its in 4WD. I had the same problem, that part is exposed to alot of water, snow, salt and so on. Or you could just replace it but its cheaper to spray it down with WD-40
Posted on Apr 18, 2009
SOURCE: Engine works but no power is produced
I have a COLEMAN 6250 Watt Powermate too, and it stopped producing 3 hrs into our blackout. I unbolted the four 7/16" bolts holding the end bell assembly, and looked at the circuit board (bridge rectifier assembly) and saw that 4 of the diodes had melted free from the circuit board. This is a $30 replacement part, and seems to be a common problem with these units. http://www.jackssmallengines.com/coleman_control_board.cfm
Other common and cheap to fix problems may be the brushes are worn out. Unscrew the phillips screws under the plastic tab on the end bell of the generator, and pull out the metallic rectangular posts attached to the copper wires. If they are shorter than 1/4", broken, or uneven, they may need to be replaced. They are about $3 each.
I probably drew too much power from 1 outlet on the generator, and it caused the board to fail instead of tripping the circuit breaker. (BTW, the repair shop told me it would cost $550 to replace the entire rotor/stator circuit board assembly. I have a strong feeling they didn't even look at any of the above parts, because they didn't have a clue as to what they were doing!)
I liken this to taking your car in because it won't start, and the mechanic saying you need a new engine!
Posted on Jun 27, 2009
Bmw speedometer
Sounds like a bad or lose fuse. Take a look in the fuse panel and look for a loose fuse or blown fuse.
Jan 10, 2013 | 1993 BMW 325
Headlights wont work, just suddenly stopped!
recheck them fuses sometimes they dont look blown but they are if not there must be a loose connection somewhere i know you have checked but retry
Jul 28, 2010 | 2005 Suzuki SV 650 S
Car intermittently loses all electrical power, when running or not. cables appear to be in good condition and are clean and tight. Everything goes, lights, ignition, dome lights, alarm system; a complete...
check the connection at the altenator and the other end of the ground away from the battery. grounds that have become corroded or loose have been known to cause strange problems. also check your main fuses in the engine compartment fuse box to make sure non are loose or corroded
Oct 03, 2009 | 2000 Subaru Outback
Rear view door mirrors stopped working working on Lexus RX330-'04
sound like a possible short or loose connector in the power bezel. you need to pop it off and check the connection
Aug 28, 2009 | 2004 Lexus RX 330
My 2001 volvo v70 lower center console has stopped working.
Had the same problem. Wiring harness (under the driver's seat) junction had come loose. Pulled apart, cleaned, put back together, everything works fine.
May 17, 2009 | 2001 Volvo V70
Electrical Supplies Logo
141 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
