Question about Canon imagePROGRAF IPF710 Printer
Lift the release lever and reload the paper - Canon imagePROGRAF IPF710 Printer
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Standard top bin full?
I suggest you remove any sheets of paper from top tray then lift up and release a black plastic flap found under a plastic overhang on paper exit tray. This lever (If its not broken/missing), should be free and should drop down(under its own weight) freely. If not then it will involve using the manual to remove the top cover and find where lever is jamming (usually jumped out of a guide bearing.)
regards
carmike
Feb 17, 2014 | HP LaserJet 5200tn Printer
2008 Mitsubishi release cable for Hood not working. When pulling on release inside car, the hood does not pop open to reach under and release the safety latch
I have a similar problem on my 2006 VW Passat.
I'm able to open the hood two ways:
1) ask someone to hold onto the lever inside the car while you try to lift the hood to the point where you can use the unlatch button and open the hood fully.
2) Pull the lever completely open in the car and try to find a thick screwdriver or some thick paper folded up to wedge next to the lever to hold it open while you get out and try to lift the hood to the point where you can use the unlatch button and open the hood completely.
Other than this finding a service manual or tutorial online about how to pull out whatever trim or interior covers you would need to replace the cable fully. There should be a specific replacement guide for this item since I'm sure it happens to car's at least semi-regularly
Aug 31, 2013 | Mitsubishi Galant Cars & Trucks
Cannon fax l100 how can I fix this problem
Looks like a document jam as the paper rolled up under the scanner bed.
Do you have the manual for the unit?
It is on line at mypdfmanuals.com. Just google it!
1. Lift the document release lever.
If a multi-page document is loaded, remove
the entire document from the ADF.
2. Lift the paper stack cover and pull it out completely.
Make sure the back end of the cover does
not catch the front paper guide.
3. Lower the scanning platform in the document delivery slot (this is on ththe front of the machine - a small tab you push down.
4. Carefully!!! pull out the jammed document - do not wrench it out.
5. Lift the scanning platform back into place.
6. Inset the paper stack cover (that you took out earlier.
Found it here http://mypdfmanuals.com/dref/815752
Feb 11, 2013 | Office Equipment & Supplies
I reloaded the paper tray. Now it says "no paper pick-up, even though I have 2 trays I can get neither to work. I have tried nv ram. The printer is only 3 months old and I can see nothing wrong with...
Check under the paper tray, paper lift has to be act with the help of "knoch"( a small plastic part along with the spring to lock the paper lift) while loading the tray. If its broken or nor functioning properly paper wont lift to pickup, result error shows reload the paper tay, if "knoch" is good chek under the tray there is a metal frame drives the "knoch" If its not connecting properly make the frame slight bend to ward to up side at the centre pont. load the tray and observe whether paper lift acting or not. .
Best of luck..
Vinay.Hyderabad.
vinay229229@yahoo.co.in.
Apr 18, 2011 | HP Laserjet M2727nf Multifunction Printer
How do I fix a paper jam cef for epson aculaser cxn11nf?
Diagram of doors should be above control panel of printer.
Lift ADF/Scanner up. Open door "C" just below it. Lift orange photoconductor lever up to release photoconductor. Lift photo conductor up towards you. Inspect for jammed paper and remove if necessary. Replace photoconductor, close lever and door "C".
Open door "E" on rear of printer and look for jammed paper and remove. Close door "E".
Last place to look is in paper tray. Take stack of paper out and look for paper jam. Removed as needed.
These are the three places i have had jams and you will only find the jam in one of them. Most likely it will be in back in Door E
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
HP Deskjet3845
To remove the jammed sheet of paper :
1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out. CAUTION! The paper may be covered with unfused toner, which can stain garments.
6. If you see no paper jammed under the cartridge, remove paper tray 1. The paper may not have fed all of the way into the printer.
7. Reinstall the paper tray and the toner cartridge.
8. Close the upper front door.
Mar 11, 2009 | HP Deskjet 3845 InkJet Printer
Paper jam how to remove paper when jamed in rollers
First unplug the printer from power chord.
Hope this helps .
Feb 22, 2009 | Lexmark X4650 InkJet Printer
9600 keeps telling me to RELOAD paper
just flick the paper lever up and down. dont fiddle
Jan 16, 2009 | Epson Stylus Pro 9600 InkJet Printer
Paper is jammed in the printer and cant move it
Remove the cartridge, lift the plate below the cartridge, open the rear door and lift the green lever on the side and release the paper.
make sure the setting in the toolbox is set to
Tray 1: Any size / Any Type
tray 2: A4 size / Plain Type
Rgds,
Nikhil
Dec 12, 2008 | HP LaserJet 1320n Printer
Canon imagePROGRAF IPF710 Printer Logo
old marine
old marine
