Question about Poulan WeedEater Hedge Trimmer 25cc Engine
Weed Eater Lawn Mower, Model # 96114000317, Spark Plug Gap
SOURCE: Where can I find a manual for the PE550 weed eater
i have a weed eater edger and the starter rope broker
Posted on Aug 23, 2009
  • 110 Answers
SOURCE: very weak spark.....how do I check the points
Unless your engine is more that 25 years old (not possible for an Enduro), there are no points. The ignition is solid state, which means that a weak spark will require a new ignition module. Not the end of the world - they're cheap and easy to find.
Change the plug first!
Posted on Mar 10, 2010
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
SOURCE: lawn mower cranck but wont start...
Since you already checked for spark and air I would drain all the fuel out of it and check that fuel for water. Over time some lawn mowers end up with contaminated fuel. You can see the water sitting on the bottom of the fuel if you let it stand for a bit in a small plastic bowl.
Be sure to empty and dry out you fuel can as well. Especially if the mower stopped running right after a refuel. Which is a good sign your gas can is contaminated too.
Posted on Jul 02, 2010
  • 279 Answers
SOURCE: I evidently put too much oil in the Proulan Pro
First thing is to remove the excess oil. Take out as much as you need to to get to the line on the dipstick. Next, you may want to use a little WD-40 or similar cleaner to spray into the spark plug hole to thin the oil in there. Replace the spark plug and start the machine a number of times until it runs correctly. Using WD-40, remember the term "little". Good luck...Lee
Posted on Jul 22, 2010
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
Engine tm251 sst lawn mower weed eater won't start?
Start with changing the spark plug. They love to eat plugs.
Nov 05, 2013 | Garden
Weed eater 961380017 where is oil drain plug located?
On the Weed Eater 961380017 it uses a Rato engine and the mower is made by Husqvarna, it is the same as their U.S. model 5521P. To drain the oil you have to first remove the dip stick and then tilt the mower over to drain the oil out into a pan.
Aug 04, 2011 | Garden
Will not start no spark
It could be faulty ignition coil, or bad spark plug for starters.
Sep 06, 2010 | Husqvarna Weed Eater 26 In Deck 190 CC...
Very weak spark.....how do I check the points under the fly wheel.....How do I get the fly wheel off? I just picked any weed eater product cause there was no link for my weed eater ride on mower with a...
Feb 17, 2010 | Poulan/Weed Eater No. 5000p 952711612 Pole...
String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Nov 05, 2009 | Garden
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
63 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
