Question about Toshiba 42PW33P 42" LCD TV
How to clean inside 42pw33p inside - Toshiba 42PW33P 42" LCD TV
What is the code to sync up with a sky remote
Hello
Sky remote codes for Toshiba TVs are:
Toshiba
28W93B 2563DB
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
Toshiba
156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB
536
Toshiba
2101TB 213T4B 2573DB 32ZP38
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2
063
Toshiba
14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
OK.
Oct 13, 2011 | Toshiba Televison & Video
I disconnected my TV when we were having work done in the house. At the time I had no trouble getting Sky. A new connection to the dish has been installed but I cannot get onto Sky. I have checked the...
Hello
To synchronise with sky you have to resynchronise it, as you have disconencted it and reconencted with new one. The sky remote codes for Toshiba to check with are:
28W93B 2563DB
Toshiba
536
Toshiba
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
Toshiba
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
063
Oct 05, 2011 | Toshiba 32WLT58 32 in. LCD Television
When i switch my tv on it has a habit of switching itself off. The red light will still be on and a little green light below it flashes. some days it does it somedays it doesnt. Some times it does it once...
The television is switching itself off to protect itself because there is a problem with it. It may be a bad capacitor, which is usually the case but you have to catch it before it gets any worse. Because then the television will switch itself off and not come back on. The light will just continue to blink and on top of replacing the bad capacitor the entire board the capacitors are attached to might need to be replaced as well as the power supply and main board. Please do not keep turning your television on while it needs repair because it will put itself into a coma and contact a service provider asap.
Feb 05, 2011 | Toshiba 42PW33P 42" LCD TV
My toshiba 42pw33p television show double image
If the convergence controls don't fix the issue then the convergence circuitry is most likely faulty. A Toshiba repair center will be able to get you an estimate for repair.
Oct 31, 2008 | Televison & Video
I've got a crach in the screen, only the outer screen. its a toshiba rear projection model 42pw33p.
The only listing I have for a screen is the lenticular screen part number: 23311897 cost: $158.90 from tritronicsinc.com
Hope this helps,
Dan
Jul 29, 2008 | Televison & Video
Color convergence alignment
change your convergence ICs that should solve your problem.If you need more info let me know.
Apr 08, 2008 | Toshiba 42H81 42" Rear Projection...
Where can i get a Screen for toshiba 42pw33p model ??
The model number 42pw33p is not a valid Toshiba model number. However, 42H81 is a valid number. The listing below is for model 42H81 ONLY! Double check you number before purchasing.
There are 3 screens that make up the screen assembly The inner screen is the Fresnal Screen. The middle screen is the Lenticular Screen and the outer screen is the Protective Screen. Please click on the links below to purchase these items.
Fresnal Screen
Lenticular Screen
Protective Screen
Mar 06, 2008 | Toshiba 42H81 42" Rear Projection...
No picture
Convergence ICs probaly went bad and if you continued using it it most likely took out the two flameproof resistors right next to the ICs heat sink thereby shutting the set down.
Jan 17, 2008 | Televison & Video
Toshiba 42pw33p rear projection tv
crt repair
http://www.riddledtv.com/repair/journal/Toshiba51H84/index.html
Jan 05, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 42PW33P 42" LCD TV Logo
16 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
